Question about Asko W620
W620 Drain Hose Goes Where??
Hi All,
I had a leak in the accordian valve like black rubber drain in my Asko. I bought the part locally and my husband replaced it. When we put it back the 7" black drain hose is squirting water on the floor. I saw a reference stating that the black hose gets hooked somewhere in the door compartment. Please specify where this goes. Is it on the trap door itself as I see a round pin like piece sticking out on the top interior door? Or where? Also is there supposed to be a clasp on it?
  • beilman Apr 18, 2008
    Figured it out...duh the hose goes onto the round pin.
The little black hose in the pin trap compartment gets hooked onto the round pin on the door of the pin trap access, that little hose is a bypass hose from the pump inlet
hope this helped
Posted on Aug 02, 2008
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
Dishwasher will not drain. F2 shows up on panel
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Aug 20, 2010 | Asko Dishwashers
What does code F2 mean?
Hi, Welcome to FixYa. The "F2" for Asko dishwasher indicates an issue with the unit overfilling. This can be caused by several things, faulty inlet valve, drain pump, a plugged fill switch/overfill hose or a leak which causes the overfill switch to actuate or even a plugged drain hose. ( if you wait a couple of days it may in fact start working as the water in the base evaporates ) I would start by removing the bottom toe panel to see if the base is full of water and then check the drain hose where it connects to your home plumbing. Of course make sure you turn off the power at the breaker panel. If you don't feel like these are things you can check I'd recommend calling an authorized Asko service provider. Let me know what you find. Macmarkus :)
Aug 15, 2010 | Asko D1776 Stainless Steel Built-in...
How can I open the door manually?
Check the machine is empty of water, and the power switch is off. I like to unplug it as well.
Open the door to the needle trap and drain pump (which is on the bottom left of the machine), using a flat-bladed screwdriver on the right hand side. Drain out any remaining water by pulling the drain hose off from it's 'peg' on the inside of the door.
Remove the screw that holds the red plastic handle in place.
Pull on the handle, and the door will open.
Before you replace the screw, you'll have to feed the cord to the plastic handle back into it's hole.
Aug 14, 2010 | Asko W620
Hi my asko fron load washing machine model W621 wont drain properly anymore and makes a clunking sound as it tries to spin are u able to tell me what possibly could be wrong with it & if its worth...
Not to worry, please check from the drain hose from beneath and open the hose. Look for dirt inside for clogging into the valve/drain pump. Remove and clean the valve/pump if there is dirt. If not during the spin the valves must open and drain. if not check for the controller section for fault. The clunk noise could be misalignment of the suspension or the damper unit. tighen or replace. Hope you try . Good day
Aug 13, 2010 | Asko W6021 Front Load Washer
ASKO D1776. Water in drain pan. Were does it leak from?
your connection to the sink might be your problem.. The hose from the dishwasher should be connected to a drain line or garbage disposal under the sink, If the drain line from the dishwasher goes straight down to the dishwasher thats your problem! The drain line connected under the sink should go up first then down to the dishwasher, you can fix this with a tie-tie or some tape, just raaise the drain hose and tape to one of the inlet lines to the sink, hot or cold side. Good luck
Mar 15, 2010 | Asko D1776 Stainless Steel Built-in...
Cannot afford a plumbing or to replace the
F8 would indicate a water level failure.
Check that the drain hose hasn't dropped down too low and also check that the water isn't siphoning out because the drain hose is too far into the stand pipe.
Check that the filters, especially the fine mesh one, is clean and clear.
If neither of the above, take the filters out, clean out the black grid on the right side of the sump.. Pour a kettle of boiling water into the sump getting as much as possible into the black grid. Select the hottest wash and try the machine again.
You could also look at the below points :-
Dishwasher Leaking
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Let me know, if the problem persists.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Kenmore 15129 Built-in Dishwasher
Leaking dishwasher
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 29, 2009 | Asko Dishwashers
Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Dec 11, 2007 | Asko W620
Washing Machines Logo
151 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
