Question about Acer Veriton 5500 PC Desktop
No signal input . Power working.The monitor message is'no signal input' changed to another monitor and the message is the same. Haven't chaned the memory stick yet...checked all cables fine
    Problem Solver:
  • 6 Answers
Try updating or reinstalling ur video drivers. Has worked for me in the past.
Posted on Jul 06, 2010
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
Monitor "check signal cable" message
Try first, select input source manualy.
Sometimes, it automatically trys to detect DVI source first.
Jun 19, 2013 | Samsung Computers & Internet
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Computer does not boot up
Computer has three short beeps as it starts? computer RAM (memory) related issue.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Hope this helps.
Oct 22, 2009 | Gateway GT5404 PC Desktop
Worked fine now no display
one of few possibilities, either no input form video card (possible bad video card), or loose video cord. or on flat video cards, you can choose from the menu to use digital signal or analog signal, if you have chosen what u do not have , u might have gotten that result.
Jun 17, 2009 | Acer AL2017 20" LCD Monitor
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
My Emachines_w2888 will not boot up. I get a, (NO SIGNAL INPUT).
If all you have done is upgrade the memory, take out one stick of memory and see if the computer will start up. If it acts the same way it has been acting, take out the other stick of memory and put the first stick of memory back in. You could have a bad stick of memory. Does the computer make any beeping noises when you try to start it? Those beeps are the BIOS way of telling you there is a problem. One BIOS beep means the system is starting if you have more than one beep, there could be a problem, the number of beeps along with the brand of BIOS will give you a clue as to what the problem is. Once you know the number of beeps and the brand of BIOS you can search the Internet for what the problem might be. Your monitor showing "NO SIGNAL INPUT" is its way of saying "I'm ok but something else is wrong".
Good luck
Nov 11, 2008 | Computers & Internet
The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
Oct 26, 2008 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Acer Veriton 5500 PC Desktop Logo
286 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
