Question about Goodman CLQ36AR49 Air Conditioner
It doesnt cool the house temrature down
It was working for 2 days and my house temperature didn't go down 1 degree :@
  • 29 Answers
It appears from what you say that both the indoor fan and the outdoor fan must be running. If so, you must check the compressor to see if it is running. It probably is not, but if it is, you are probably totally out of refrigerant due to a leak maybe.
Let the unit run for a couple of minutes and then feel the copper lines that are leaving the outside unit. The big one should be quite cold probably to the point of sweating. The little one should be warm.
Posted on Jul 06, 2010
Output temperature
Air conditioners will cool 16-20 degrees. So if the house is 80 degrees, 63 degrees is a good output. If the house is 72, the air will be colder. The higher the humidity, the lower the temperature drop will be because the A/C has 2 jobs, to cool and de-humidify. So if the house is humid, the drop will be lower.
Jun 04, 2015 | Heating & Cooling
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
What is the optimum operating temprature for a sumitomo sh330 excavator
if it is a water cooled engine (one with a radiator) the operating temperature would be 85 to 95 degrees c. anything over would be considered to be running hot as the energy need to push it to boiling is a very small quantity.
Dec 06, 2013 | Cars & Trucks
2004 Harley Davidson low rider engine runs hot
The manufacture recomends the oil temp runs between 200 and 240 degrees, but they state too that the oil will not start breaking down till 300 degrees. Most bikes now days have and oil filter housing adapter that circulates coolant through it, you might check your thermostat and make sure there is no debri in the radiator flues.
Dec 03, 2012 | Motorcycles
My A/C is operating outside the house, but there is no cool air inside the house. We set the temperature onto 84 F Degree, however, the inside-house temperature has already reached 88 F Degree. Can you...
With such limited information the following is the most likely problem.
1. The fan outside is running but the compressor is not.
2. The inside air handler blower fan is not working.
3. The system is froze up and not allowing any cold air to come out of the vents.
Hope this helps
Sep 19, 2011 | Honeywell Heating & Cooling
I have a Honeywell EMM-3 Electronic MiniZone Panel and my thermostat is set at 78 degrees but the house is registering at 89 degrees and it won't cool down although the a/c has been on all day for...
Zoning, in the A/C world, refers to different areas of the house which may be cooled to different temperatures. Zoning is accomplished by closing/opening vents.
Zone 1, 2, 3 etc. do not have any particular meaning, except to indicate zone control flappers 1, 2, 3 etc. which are physically inside the ductwork which determines the zoned area.
Just because you have this fancy thermostat, does not mean that your house is actually zoned, but I am not to sure why such a thermostat would be purchased if it was not (unless it was free).
Zoning uses dampers. Is there air blowing out of the registers?
:o).
Jun 04, 2011 | Heating & Cooling
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
As to your question 'will 75 cool the house?' The answer is 'yes' - if the outside temperature is low enough. Typically speaking you can expect your central AC to cool a properly insulated house to a down to a temperature of about 20-25 degrees lower than the outside temperature. For example - if the outside temp is 95 degrees. You could expect to get your house down to 70-75 degrees. If the outside temp is 110 degrees then you could only expect to get the house to 85 or 90 degrees.
So .. as you can see - your 'inside' temp will be directly affected by the 'outside' temperature.
As to the operation of central air; it is very simple.
I would suggest that you not pay 'too much attention' to what you have the thermostat set on. A comfortable temperature - is a personal thing - so - I would set it somewhere - say 72 and see how I (and others in the house) was handling that setting.
If you want it 'cooler' just 'notch' it down a degree or two - if you need it a little warmer - turn it up a degree or two. Do this "fine adjusting" till you have the temperature setting you are comfortable with.
Usually the more you can leave your thermostat alone the better off you will be from a comfort position and an electrical useage standpoint. Obviously, the higher you have your thermostat set the 'less' it will cost you on your electric bill.
How high you set the temperature is a balance you have to come to based on how comfortable you want to be - matched with how much you want to hold down the electric bill.
hope this helps
Aug 14, 2010 | Honeywell Heating & Cooling
I have a 2 1/2 ton unit. If the outside temperature is 95 degrees. What should I expect from my unit in cooling my house.
If properly charged your unit should perform fine, having a dirty condensor at that temperature can cause problems not easily recognized.
A well insulated house should be able to maintain a 20 degree temperature difference whether its summer
or winter. No Mechanical cooling or heating involved
for at least 6-8hrs if not more.
If it never cools when it is 95 degrees outside the ambient outside temperature is not the problem.
At 95 degree out side air you should be seeing inside discharge air temperatures betwenn 48-55 degrees.
It is the load in the house that determines how long the unit will run at 95 degress.
Jun 21, 2010 | Goodman CKL24AR24 Air Conditioner
Thermostat takes too long to cool down 1 degree
Thermostats don't cool or heat. They are just the control device that tells the furnance or AC to operate and register the present temperature and tell the furnance or A/C to shut off, once the desired temperature has been reached.
Most programmable thermostats will take at least 1-2 weeks to "learn" how long to run the furnance or A/C in order to reach the desired temperatures you've programmed into it, for the time you want it be that temperature. Variables such as extremely hot days and higher humidity will also affect your cooling system.
Give it a little time to self-learn and it should adjust itself after a week or two of operation. You might want to take some time to review and familiarize yourself with the owners manual to see what Hunter advises for setting up and using the thermostat.
You may need to have your A/C checked to see if you're running low on freon, or need to have the coils cleaned, need to change the air filter, etc.
Hope this helps and best regards!
Aug 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Goodman CLQ36AR49 Air Conditioner Logo
96 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
