Question about Fuji FinePix S5000 Digital Camera
When I try to take a picture, the LCD displays a lot of colorfull squiggly lines instead of the scene that I want to capture. When I turn it ON, the Zoom lens extends normally, then the colored lines appear with the following settings on the screen. Auto, 1M 178, ISO 400, ! plus a hand icon, AUTO, 4, F2.8. No matter which mode I choose, the same thing happens. Looking through the EVF shows the same thing. Note; I can view several good pictures that I took before the problem showed up. If I press the the shutter button as if taking a picture, I get a replica of the colored lines instead of the scene that I was trying to capture. When I try to view my pictures, the original pictures show up as they normally do. But the last picture shows up with the colored lines.
  • 3,866 Answers
This would be caused by a defective CCD sensor inside rad this advisory from canon below:
http://www.dpreview.com/news/0510/05100602canon_ccdproblem.asp
You might want to consult canon for repairs as they are aware of such defect, its all across models here not just yours even nikon is experiencing these issues. Most of the boards where manufactured over seas calling for this advisory.
Thanks for your visit here at fixya.com please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 06, 2010
White lines on image however when capturing on dark areas and on video mode, it produce a perfect image
Not clear when you have white lines. While looking on the screen or really on a image.
Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen.
Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Nov 05, 2013 | GE 14MP Digital Camera with 5X Optical...
Multiple squiggly lines fill the LCD screen, after
Sounds to me like your inverter has gone bad. Typically it's situated just below your LCD. To get to it you will have to take out the screws around the LCD bezel. It's a long, skinny circuit board that the LCD plugs into. You can usually find a replacement on Ebay. Just be sure that you're ordering the correct part, otherwise it may not fit or work properly. I've also had times when the entire LCD was going bad and the display was full of squiggly lines. It's hard to say which one is the cause. I would try replacing the inverter first. That part is usually much cheaper than the LCD is.
Apr 10, 2010 | Toshiba Satellite M60 Notebook
Canon sd900 will only take pictures that don't require a flash
Press the "DISP" button. Button on the top right of the bigger circle control button.
You can turn off the display if you want to conserve battery and use the viewfinder. So you probably accidentally turned it off. You can use that button to turn on/off the LCD display or change between two brightness settings on the LCD.
Hope that fixes your problem.
Apr 19, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Shattered screen when i turn the t.v on
The LCD display will probably cost around $1100.00. Unfortunately, I would say it's time to purchase a new one. The cost factor of the displays are a major issue in our industry.
Mar 22, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Lines on my monitor
Samsung have a lot of liquid crystal display there. The solution is simple: the replacement of an MCU will be able to repair.
Samsung LCD MCU sales:
http://www.dgdw.cn/lcd%20mcu/SAMSUNG%20MCU%20English.htm
SKYPE: cqrising
Dec 13, 2008 | Computers & Internet
Pictures are black
My 4300 works fine until this week. No picture display on the LCD screen. Settings like date, exposure, etc.. are fine on the LCD screen. Able to get into setup mode and the colour menu selection box is fine. This shows that the LCD screen is working fine. Prior to this happening, I notice that when I took pictures in zoom mode, the picture turn out to be orange. I suspect this is caused by electronic failure. Light entering the lens cannot be transmitted to the LCD screen. Some photoelectronic stuff had reached its MTBF (mean time between failure)? Is there a way to save this camera?
Mar 17, 2008 | Nikon Coolpix 4300 Digital Camera
Sony DCR-TRV230E Digital 8 Playback Problem
Hi! If the images you are capturing are hazy with zig zag colors etc...the imaging IC is faulty.If the problem in Display unit only but the captured image is OK when you transfer the same to PC..then LCD may be having problems. We can help you in spares of Sony and we can also offer the service manual. Kindly let me know after your examination. Regards, Sivaram.V Videolabs
Nov 28, 2006 | Sony Handycam DCR-TRV240E Digital...
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
246 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
