Question about Dryers
I have a Simpson Maxidry 1200 and the heat does not work.
  • Dryers Master
  • 12,061 Answers
Http://spares.alliedappliance.com.au/catalogue/catalogue_4_4_6_73_0ca480.html
Above are spares.
Most likely the element, or perhaps a sensor, or even the "Brain" you will have to troubleshoot to tell.
http://www.acmehowto.com/howto/appliance/dryergoe.php
Above is a DIY self help how to site...
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f9974b45b191cb2585257027004f8b0b?OpenDocument
Aervice manual above.
Posted on Jul 06, 2010
Can you please tell me where I can get a Simpson Maxidry 1000 user manual or any other kind of manual for this dryer?
Try this link:
http://fasterbetterdownloads.com/simpson-maxidry-1000p-user-manual/
Jun 20, 2015 | Dryers
Air no longer venting out back of dryer
sounds like the fan not working.
Apr 06, 2013 | Dryers
Simpson maxidry 362 dryer not heating, everything else seems ok
Two things to check. First, check for any lint in the screen or lint build up in the exhaust. this will restrict airflow. Secondly, check to see if the heating element is bad.
May 15, 2011 | Dryers
Simpson Maxidry 1200 S Clothes Dryer. Dryer spins, Blower working, but heater doesn't work. I've got the element out & it checks ok. What next please?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
G'day my Simpson Maxidry 1000 is spinning but is not heating up
the element is at the front of the unit.if u have no heat it is proberly your element, broken wire, timer or thermostat. if u have an electrical test meter i can tell how to test 4 faulty component. 90% of the time i have found it is the element . please reply 4 more help. element replacement is not too expensive.
Apr 12, 2010 | Dryers
Simpson Maxidry 457 not heating
Check thermal cut outs/ Element Should read around 32 ohms on a multimeter if its ok...
Apr 09, 2010 | Dryers
Simpson Maxidry 1200 S Cloths Dryer. Our dryer whilst spiining and heating is not adequately drying clothes. When I took it down to check test it appears that the belt to the central lint fan may have been...
Yes - the vent exhausts humid air, and draws IN fresh dry air. So the humid air is staying trapped in your unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 08, 2009 | Washing Machines
Replacing the belt on a simpson 362 maxidry
Check out applianceaid.com good easy site to follow
Apr 19, 2009 | Electrolux Dryers
How to fix a Simpson Maxidry 1000p?
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Jul 26, 2008 | Dryers
Dryers Logo
119 people viewed this question
Top Dryers Experts
