Question about Aiwa NSX-AJ20 CD Shelf System
On the left side cassette will not seat the cassette. The door does not open every time. on the right side the deck opens and closes but the cassette will not play.
    Master:
  • 501 Answers
Buy a new one
Posted on Jul 06, 2010
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
Tape will not turn
The more detailed the description of the problem, the better for diagnosing the root cause. Thanks.
It sounds like you have a couple of problems. I'll address them as you have them numbered above.
1. Decks typically have belts to drive the various 'reel' mechanisms. Therefore, they can slip without breaking anything inside the machine or the tape. Your first symptom leads me in that direction.
2. That it migrated is mysterious, unless Sony is using a common motor to handle both decks' reel duties.
3. This symptom may have something to do with the root cause of both sides jamming...
Do the cassette well doors come off, say, for cleaning? Could they be dislodge? If so, they may have something to do with the jamming problems in # 1 and #2 as the doors play a part in positioning the cassette and holding it in place against the reel motor cogs. How do the doors operate with NO tape inserted?
Does it take excessive force to close the door only WITH a tape? make sure the tape is fully seated before closing the door. The capstans (directly below each reel cog) have to engage through the small holes at the lower edge of the cassette. They should be straight and clean. Any dirt or oxide on them will cause problems as these are what move the tape at the precise speed necessary for good playback or recording.
My hipshot recommendation, otherwise, is to look around inside the cassette wells very carefully for any foreign matter, debris, dust bunnies.
Do you maintain the deck as recommended?
Apr 02, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
Numark CD mix 3 right cd door seldom opens
Defective load belt or defect in laser assembly
Sep 11, 2008 | Audio Players & Recorders
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Feb 04, 2008 | Audio Players & Recorders
Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
Dec 25, 2007 | Audio Players & Recorders
Cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
Aiwa NSX-AJ20 CD Shelf System Logo
217 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
