Question about LG LB1200ER Air Conditioner
I have this model of air conditioner and it shuts off from time to time. It will run for a while and then power down. Then when you try to restart it will run for a few mins and shut down again. But I tried it in a different out let and it will run for a longer period of time. It is not tripping the breaker on any outlets. Is this an issue with the compressor getting over work and it shutting down to cool off?
  • 1,921 Answers
That is a possibility. Try feeling the cord when this happens, is it getting hot?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Jul 21, 2017
SOURCE: my brand new lg air
your AC have a thermister problem
if u replace the thermister your AC will be OK.
Posted on Jun 08, 2008
  • 67 Answers
SOURCE: air conditioner keeps tripping breaker
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
rockitman187
  • 2559 Answers
SOURCE: Air conditioner compressor keeps shutting down
This is due to thermal overload,Which can be caused by low oil in the compressor,the fan has stopped running on the unit outside,Dirty coils,or just a worn out compressor.Although this is thermal overload,It has nothing to do with outside temperature,But rather the internal temperature of the compressor itself.
Posted on May 19, 2009
  • 10865 Answers
SOURCE: dometic rv air conditioner over 100 deg. trips breaker.
The problem is that when u add up the electrical draw from all of these appliances running full bore, your draw exceeds your available amperage. Now you are doing the math and saying no...... Let me tell you why. It is rare to find a situation where a 100 amp service actually porovides 100 amps. You almost always have voltage dropo. And when you are adding extension cords to the mix the drop is even more. That said, When you are using the AC try to minimize the use of other appliances, especially the microwave which is a big draw too.
Posted on Jun 25, 2009
  • 9 Answers
SOURCE: problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
Posted on Jun 03, 2010
Mr slim ac shuts down and restarts to frequently.
Changing the setting won't affect the way the unit works, only how long it runs for. Rapid switching off and on will kill your compressor in time - check the refrigerant level. Usually short cycling on lp switch.
Oct 19, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
A/C runs fine for 7-8 minutes, then shuts off
Refrigeration problem. Must be a bad thermostat.
May 11, 2013 | Sharp AF-S120FX Air Conditioner
Setting air condition for 1st time
Check whether you have set the OFF timer.
Check thermostat / thermistor.
May 26, 2010 | NewAir ACP-1000E Portable Air Conditioner
Amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jun 30, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
Evaporative air conditioner not working
Wish there was more that I could do to help but you may need to have someone or yourself check for anything shorted/grounded and also make sure the voltage is correct to the solenoid.
Feb 12, 2009 | Heating & Cooling
HAVE A COLEMAN MODEL DRHSO601CB --- THE UNIT WILL RUN FINE FOR SEVERAL HOURS WITH GOOD COOLING AND THEN PERIODICALLY THE TROUBLE LIGHT WILL COME ON THE THERMOSTAT AND THE UNIT HAS SHUT DOWN. TO RESTART -...
You may have a low pressure or high pressure switch tripping out the board as well. You might try cleaning both the indoor (evaporator) coil and the outdoor (condensing) coil. Be sure to turn off the power source before servicing this.
Jun 30, 2008 | Coleman Heating & Cooling
Duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
Jun 28, 2008 | Dometic Rooftop RV Air Conditioner
Edgestar AP550Z won't heat, goes into some sort of alert mode
http://edgestar.com/ownersmanuals/AP550Z_wire-fix.pdf
This could apply to at least one of your units. Apparently these models have had some trouble with the compressor capacitor wires coming loose. If they're barely touching they could cause the compressor to run intermittently and possibly overheat. The compressor runs in heating and cooling mode.
Dec 04, 2007 | EdgeStar Portable Air Conditioner Heater
LG LB1200ER Air Conditioner Logo
56 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
