Water is not draining forom my hampton bay air condiotioner. It is gurgling and you can see water inside the unit. I have tilted it more in the window there is some water dripping but there is still water in the unit. I do not see a drain hole on the bottom of this unit.
  • 47 Answers
Allot of Window units do not have a drain anymore. The condenser fan picks up the water that lays in the bottom of the unit and slings it against the condenser coil to help keep it cool. If it is not leaking water inside the house it is normal to have some water in the bottom of the unit. This is verified by not having a drain hole or hose. As an A/C service tech I didn't care for this design as allot of people thought that there was a problem when there was not. They also tend to be a little noisier as the water makes noise when it is being thrown around inside the unit. I hope this helps
Posted on Jul 06, 2010
  • Thomas LaCroix Jul 29, 2013
    Thanks Sounds good to me I thought that there would be a cooling recycling process that accuredd
I have a Hampton Bay window air conditioner unit. It was leaking water from the front below the grill and now it has stopped working. I think the drain holes may be clogged. I cannot figure out how to...
Good chance the drain holes are clogged but that shouldn't cause it to stop working. I believe you need a service call or if the unit was inexpensive, scrap it and go for a new one. I repair them but most AC companies won't touch them. Sears might tackle it.
Sep 26, 2013 | Hampton Bay Heating & Cooling
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
My hampton bay air conditioner has started leaking badly after running it lfor a few hours, from the front right side
For window mount units, the unit must slope towards the outside. Water is a normal byproduct of refrigeration, like condensation on a glass of ice water.... Volume of water is not an issue, water dripping inside is. All water is intended to go outside, via unit slope.
Jun 28, 2011 | Hampton Bay Heating & Cooling
Water is not draining out the back of the window unit and water is blowing out the front and fan is making a noise
Kathy, there are 2 reasons this happens.
1. the unit is not tilted down at least 1/4" on the outside of the window.
2. The drain hole in the condensation pan (under the unit) is clogged.
Resolving the above (either one or both) should solve the problem.
In the meantime turn the AC unit OFF.
Hope this helped you.
Jun 23, 2011 | Hampton Bay HBLG5004 Air Conditioner
My AC unit is builing up water inside it. What could be the problem??
air conditioners condensate ( create water ) in normal operating conditions, so you could assume that nothing is WRONG.
but there should be tubing or drain lines on air conditioning units that run off the excess water, and dirt / lint dust may have the water drain lines clogged , and youd need to clear the lines to allow the water to escape to where it is intended to go
Jul 31, 2010 | Hampton Bay HBLG5004 Air Conditioner
Window unit is not draining, tray is filling with water
Remove the unit from the housing. Using a special cleaner, called coil cleaner which you can purchase at any AC shop clean the coils, this should eleminate the problem.
Sep 08, 2009 | Kenmore 75085 Air Conditioner
My airconditioner is leaking water from the front just below the control panel. A huge puddle forms every 30 minutes or so. Could this be an installation problem?
the back of the unit needs to be the lowest point. It sweats inside and needs to roll to the back where there is a drain hole
Jun 24, 2009 | Hampton Bay HBLG5004 Air Conditioner
Water has accumulated in my air conditioner...
You need to check to see if the unit is off-level, as it should be. From the outside, the unit should appear to be slightly tilted to allow for water run off. Also, check to make sure the water drain hole or holes are not clogged with debris. Remember, an air conditioner is also a good dehumidifer and the water that it removes from the air it is cooling must go somewhere.
Sep 11, 2008 | Hampton Bay HBLG5004 Air Conditioner
Got a leak in the front of my air conditioner
There is no valve. The water condensate from the cooling coil flows toward the back of the A/C where it is evaporated or drained. Tilt the A/C a little toward the back and see if that helps speed up the drainage.
Jun 08, 2008 | Hampton Bay HBLG5004 Air Conditioner
Heating & Cooling Logo
238 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
