Question about JVC TD-W254 Single Cassette Deck
I am tried many time to record from cd line in (Rec) into a cassette but i heard no sound detected.
    Master:
  • 502 Answers
Try adjusting line level input,when its on record,with pause button pushed in as well.you should see two LED lines jumping up and down,recheck yr connections.you have got to see those LEDs lights movihg up and down as they are yr sound level
Posted on Jul 06, 2010
How do you connect Sony rcd-w500c to Sony tape deck to record tapes to CDs?
Line Out from the CD player/recorder goes to REC IN on the tape deck
Sep 09, 2014 | Sony RCD-W500C 5-Disc CD Recorder
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
I have 2 boom boxes where cd's spin but no sound.
Its probably a lens failure, its quite common, try cleaning the lens,
if all else fails, try turning the unit upside down and load the disc, sometime this for some reason - resets the lens if slighty out but its not fact, just something i heard
Jan 22, 2014 | Sony Boom Box With CD Player & Cassette...
Convert cassets to cds on classic recorder model cdr200
Connect the Play or out from the cassette and connect to the rec or in on the CD recorder using some descent RCA cables. Good luck!
Jan 13, 2013 | Classic Electronics CDR201 CD Recorder
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
Problem with Sony DSR 1500A won't record error flashes "Rec Inhib
dear,
the rec inhbit cable is faulty in this case ...
u need to replace that (holder assy,MIC.)
Regards
Jun 14, 2009 | Sony DSR-1500 Mini DV VCR
I am trying to hook up to my copmputer for recordings and have horrible feedback?
Salutations welove2scuba,
I would first ask how you are connecting the computer, it would be best to use a "Line In" jack to your computer if you have one. Using the microphone jack could cause issues as it is a powered connection and could be causing your feedback.
A good way to connect a computer to a receiver would be to treat it as if it were a cassette recorder. Most receivers will have a "Play (out)" and "Rec (in)" for a cassette deck, or DVD recorder and in some cases VCR's. If you connect the "Rec (in)" to the "Line In" jack, this should give you a clean signal with out any additional amplification to avoid interference.
Cordially,
Jon
Go Ahead. Use Us.
Jun 09, 2008 | Audio Players & Recorders
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
Lost the manual, can't get hooked up
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
May 28, 2007 | TDK DA-3826 2-Disc CD Recorder
JVC TD-W254 Single Cassette Deck Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
