Need to remove through wall fedder air conditioner
I believe it has a sleeve
  • 29 Answers
If it has a sleeve, just remove the front cover and give a little yank on the unit and it will start sliding out of the sleeve. Unplug the unit first, and the unit will slide all of the way out of the sleeve and you can just set it on the floor or wherever.
Posted on Jul 06, 2010
Whats the right settings for the window air conditioner.
i operate my a/c's in summer at 72 to 74 degrees. in the winter at72 to76.
Jul 30, 2015 | Fedders AED24E7F Wall/Window Air...
Looking for replacement of Fedders model T1A10W7A (not sure if installed in a type a or b sleeve). Which model can I replace with?
I suggest that you measure the sleeve's dimensions and shop the a/c dealers. They should be able to match you up with something of comparable BTUs, but more efficient.
Aug 24, 2013 | Fedders AZ7A12W7A Air Conditioner
Need specs for Model A6Y12F2D-A
Follow the link below and it will take you to a site where you can download the user manual
http://www.retrevo.com/samples/Fedders-Air-Conditioner-manuals.html
Mar 29, 2011 | Fedders A6Y12F2D Thru-Wall/Window Air...
HOW DO I GET MY FEDDERS AIR CONDITIONER BACK TO FARENHEIGHT
Problem with Fedders (A6R12F2A) Air Conditioner
FARENHEIGHT
Nelvie: silverslipper@candw.ky
Aug 20, 2010 | Fedders AED24E7F Wall/Window Air...
I have a 27 inch wall sleeve can a 26 inch friedrich unifit work?or do I need a 27 inch unit
the a/c units keep getting smaller, when unit replacement is slightly smaller , the extra space can be filled with a piece of plywood or rigid foam insulation with a thin layer of plywood, any edges seen from inside can be covered with trim, make sure the wood covers entire bottom layer of sleeve to properly support. or just find the larger unit if you can. hope this helps.
Apr 23, 2010 | Fedders A6U14W7B U Chassis...
Can Fedders Model #ABQ10F2A be put in the wall sleeve rather than on the window?
Yes, provided the outside portion of the a/c reaches through the waoo adequately to allow for the transferrance of heat to the outside.
Regards, --W/D--
Jul 29, 2009 | Fedders Heating & Cooling
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
Fedders PTAC/PTHP Condenser Fan
What is your model number, maybe we can help.
Greg
Aug 07, 2008 | Fedders AED24E7F Wall/Window Air...
Can the LG Electronis LWHD1500ER air conditioner be installed through the wall, what wall thickness max., and is there a sleeve to assist in doing so.
I don't believe that this unit can be mounted in a through the wall application. My database does not show a wall sleeve for this unit. The biggest reason will be the side vents for the condenser heat exhaust. I would stick to the manufacturer suggested window application.
Jun 30, 2008 | LG Heating & Cooling
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
