Question about Hannspree HANNS.G HX191D 19" LCD Monitor
Monitor gets signal from computer but doesn't display. Monitor will display message that says no signal when unhooked from computer but will not display menu
  • 39 Answers
Sound like it could be corrupted video driver. I would try holding down the F2 key to reach the system bios. Select vga for the video display if in the bios...then save and restart. If you can't get to the bios screen, try F8 and see if you can get safe mode...if so...it should allow pc to use the vga driver and thus hopefully display will work. If you get in and see windows, then you most likely ned to remove the display driver and reinstall it.
If still not working, try hooking monitor to another video port. Might need to get a conversion adapter to fit to vga port, or dvi port or whatever else you might see.
Posted on Jul 06, 2010
Reasons of y signals not going to the monitor
Is the monitor showing a blank screen or is it showing the message NO SIGNAL??
If you have a Desktop try the steps below:
If it is showing the message NO SIGNAL, then the video card in the computer is bad, because when the monitor is bad, it will show nothing at all. To isolate the problem plug another monitor on the computer and see if it displays. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original Monitor is bad. If the Borrowed monitor displays the same as your original, then the video card in the computer is bad.
If it is a laptop try the steps below:
May 24, 2012 | Intel Motherboard
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Princeton Digital VL1716 Monitor "No Signal Message"
Roxio Changed Your display settings on the dual display.
Right Click on desktop>goto Prefences>
You should see both monitors indentfy the one and change it to a lower resolution.
Apr 28, 2009 | Princeton Digital VL1716 17" LCD Monitor
No Signal message
This is a message the monitor displays when the video cable is disconnected or the computer has no video output. Could be the computer is simply entering power save mode. Does the screen come on when you move the mouse or press a key on the keyboard?
Dec 28, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
When i turn my monitor on it is saying that no signal or cable is not connected but ihave evrything connected
The monitor will display that message until the computer starts and outputs a valid signal to the monitor.
If the computer is on and you still get that message, then you may have a bad video card/video circuit or a bad cable between the computer and monitor.
Oct 25, 2008 | Computers & Internet
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Hannspree HANNS.G HX191D 19" LCD Monitor Logo
375 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
