Question about Sony Ericsson W350i Cell Phone
The cover has been broken how mugh will it take to buy a new hosing?
The cover belt is available in sony service-center just in 450rs.
Posted on Jul 11, 2010
How can i fix the hose fitting
I assume you mean the hose fitting on an air hose. Go to Lowes and the have barbed fittings with a hose clamp that you can splice a broken hose. If the fitting is broken, buy a new one with a barbed male end and fasten it with a hose clamp.
May 24, 2014 | Saws
Tip
Broken dipstick removal on 1.8l Nissan Sentra.
There have been issues with dipstick handles breaking off and dipstick stuck in tube. Here is a simple way to remove that broken dipstick. On the valve cover there is a hose that leads to the intake tube. Remove this hose and with a blow nozzle blow compressed air into the valve cover. The broken dipstick will shoot out of the tube. Simply install the new dipstick into the tube.
on Feb 13, 2010 | Nissan Sentra Cars & Trucks
Leaky valve cover on my jdm subaru
The only thing you might need to buy beside the gasket is any rubber parts that have been damaged by the leaking oil.
Check your radiator hoses, heater hoses, and vacuum lines, because motor oil will "rot:" rubber.
You need only replace hoses that are "spongy"and are wet with oil.
Be blessed.
Feb 16, 2013 | Cars & Trucks
How to change thermostat
Instructions
    • Trace the top radiator hose from the radiator to the location where the hose secures to the engine. The metal cover that the hose connects to houses the thermostat.
    • 2Remove the two 10-millimeter bolts that secure the cover onto the engine with a wrench. If you cannot reach the bolts or you are using a socket/ratchet, remove the radiator hose from the metal cover by removing the radiator hose clamp.
    • 3
    • Lift the metal cover off the thermostat to expose the thermostat. With the radiator hose still attached to the cover, lift upward on it to drain the fluid back into the engine. Push the cover and the hose off to the side. If you removed the hose, simply lift up on the metal cover and place it off to the side.
    • 4Pull the broken thermostat out of the engine and place a new one into place. The new one should be orientated in the same manner as the old one to ensure proper fluid circulation.
    • 5Lift the old gasket off the engine and place the new gasket into place. The new gasket should remain dry throughout this process.
    • 6Bolt the metal cover back onto the engine using the old bolts. If the radiator hose was removed during the tear down process, secure the hose back onto the metal cover with the radiator hose clamp.
Aug 29, 2012 | 2002 Dodge Neon
My screen from my toshiba laptop equium u400 145) is broken but its only the plastic cover. How can i fix that?Can i buy a new?
Yes of course you can buy a new one. To fix the broken cover you should replace it with a new one.
You can remove that but take caution and if your not sure how to do that, get someone who can do it for you, specially a qualified technician. Ask the vendor of your laptop about the plastic cover replacement.
Dec 23, 2009 | Computers & Internet
Where to buy a new battery cover for garmin 60c
Hi...
If you want o buy a new GPS battery you need to visit the ebay site
www.ebay.com
you can find there many accessories.
Good luck !!!
Regards
PCmania
Jul 11, 2009 | Garmin GPS
Dirt doesn't make it to cannister ...it used to have the spin around affect now it just sits there but some dirt is leaving floor....it is in the hose..I have cleaned ALL filters ...YUCK......help
You have a broken belt. Turn the vacuum over and remove cover plate. You will probably find a broken rubber belt. Buy a new belt for your vacuum. Remove the brush , install the new belt with the brush. Put cover plate back on. You are ready to go!
Jim
Jun 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
Broken garden hose adaptor
We have the same pump and problems. I have attempted a few fixes with PVC sealant and hose clamps to the current adaptor, however the adapter is still continuing to crack. The adapter is removable- carefully so as to not damage the small eyelet it attaches to, (or in our case, it came off on it's own) and can be replaced by any adapter that fits- they can be found all over at lowes or home depot. I am personally going to try using a broken hose and clamping it directly to the eyelet. This is not a good reason to buy a new pump- they fix too easy!
Mar 29, 2009 | Rule 1800 H53SP-24 Swimming Pool Cover...
Item stuck between drum and washing tub
no has to be completely dismantled unless you can get it out throw hose, call sears buy service smart agreement will cover up to 500.00, its a 2hr 2 man job to take apart and needs new center seal , a serve smart agreement is coverage on already broken appliance and 1 yr warranty that covers taking dryer off and on
Jan 20, 2008 | Maytag MAH2400A Front Load Washer
Washing machine is leaking from the bottom
try looking at the tubes where the filter is. remove the front cover at the bottom and check the filter. worth a shot
Nov 13, 2007 | Samsung WF203ANW Front Load Washer
Sony Ericsson W350i Cell Phone Logo
71 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
