Question about Refrigerators
Maytag 27.3 cu ft model #MSD2756GEW freezer freezing refrigerator side not cooling
    President:
  • 1,554 Answers
Check the air damper if it opens as you adjust the temperature control. If yes then check the freezer fan motor. First, disconnect the unit from the power source then remove the freezer shelving.
Loosen the two top screws and remove the two bottom evaporator cover mounting screws then grasp the bottom of the cover then carefully pull it forward and down to clear the upper flange.
Disconnect the evaporator fan motor leads. The wire leads are self-locking and it is important to squeeze the clip before pulling the leads off the terminals.
Remove the evaporator fan motor assembly and place it on a work surface. Connect the motor terminals to a service cord and plug the cord into the 120 VAC power source. If the motor fails to operate, it is defective and must be replaced.
Here's the service manual for further troubleshooting.
Posted on Jul 06, 2010
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Hello, the refrigerator side is not cooling, but the freezer is working perfectly. Our fridge is 26 cu instead of 25.6
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
FREEZER NOT FREEZING
Hello Drdean825,
I understand that you are having a problem with your Refridgerator. The problem is that your unit is not cooling/freezing. I have a tip that you can follow that will show you how to check the mechanical side of your Maytag Refrigerator. If after you follow this tip you can not find what is wrong with the unit you can repost with make and model of your unit.
Tip for Mechanics on Refridgerator
Thank you for choosing FixYa.com
Justin
May 11, 2011 | Maytag MTB1891ARW 18 cu. ft. Top Mount...
Refrigerator side not cooling very well, freezer side working fine
on the fridge site check settings . if ok t could be fridge thermostate problem. this type of fridges have 2 thermostats one for freez and one for fridg
Mar 02, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Freezer is ok but fridgewont cool model msd2561kes done7at2four@sbcglobal.net
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
I have a maytag side by side refrigerator freezer and the lower part of the freezer where the cooling coils are freeze up and won't allow the air to cool the refrigerator side.
Sound as though you need a defrost timer that is located around temp control and light in fridge side.If it is faulty it will not go into a defrost making the freezer ice up and cause alot of trouble.hope i helped thanks:)
May 12, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
