Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer will not heat
Dryer worked fine on the load before then did not produce heat on the next load
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 18, 2011
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
Dryer drum rotates with on heat produced maytag 90series electric
heatman101
Jul 24, 2011 | Kenmore 63942 Dryer
My gas dryer stopped producing heat produce heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Maytag Atlantis MDE7400A Gas Dryer
The dryer is not producing heat.
heatman101
Oct 05, 2010 | Maytag PYG2300A Gas Dryer
Maytag neptune gas dryer dryer will run but the igniter will only ignite part of the time, thought we had a bad igniter put in a new one, it lit up right away dryed one load completely dry, put in the next...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Maytag Dryers
Tumbler turns, but no heat. gas line is open and looks good... what might be the problem?
Upon starting the dryer you should hear the clicking noise of the spark ignitor. If heard that is fine. Next remove all exhaust vent tubing and clean out thoroughly. The moister sensor detects any lint build up and will put the heat burner into a check mode untill the lint build up is removed. It was designed to prevent fires to start. If cleaned and still does not produce any heat replace that moister sensor
Jun 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
My maytag dryer is not staying hot to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Maytag Neptune MDG9700A Gas Dryer
Not enough heat is produced from the dryer
heatman101
May 13, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Our Neptune gas dryer seems to work fine but suddenly produces no heat. The vent is clear and the gas line attached and open.
Look at the glow ignitor. If it is broken then it needs to be replaced. About 20 dollars, and a 5/16 wrench will fix this issue, just make sure that you unplug the dryer before you start touching the electrical. This piece is located in the bottom of the dryer behind the back panel.
May 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
141 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
