Question about Refrigerators
Refrigerator door is harder than normal to open
    President:
  • 1,796 Answers
Hi!!
That usually happens when the door rubber seal or the sealing surface on the fridge get dirty. Using dish soap and water wipe both surfaces clean.
Don't forget to rate this post. Good luck!!
Posted on Jul 06, 2010
When I close my freezer door, the refrigerator door pops open.
That's normal due to the pressure created when you close one door it forces the other one open. Mine does that but only if I close the door a little harder than usual.
If it does it all the time when you close the door easily, then maybe the door magnets need to be replaced.
Hope this helps.
Mar 22, 2015 | Refrigerators
Vacuum light on?
In 90% of the times, from my 5 years experience with subzero repairs, it will be leaking evaporator coil, compressor will run longer then suppose to (it still might keep temp). But first You need to check on all fan motors if they run. Also visually check if there is any snow or ice builds up in freezer and refrigerator compartments. if everything looks normal, then You need a serious repair. Here is video I made how to replace evaporator coils. Hope that was helpful!
Mar 07, 2015 | Sub-Zero 650 / O Bottom Freezer...
How do I prevent the fridge door from sticking too much and making it hard to open
Make sure the gaskets and surfaces are clean, any grease on them will make them hard to open. Check the hinges are free and not gummed up. Spilled coke etc, will also cause them to stick due to the sugar acting like glue. Putting hot food in there mayl also cause this problem.
Feb 25, 2015 | Westinghouse Refrigerators
Why does subzero refrigerator door closes tight
It's a big door. You should check the refr drain. If that's blocked it will be harder to open than normal.
Jul 13, 2014 | Sub-Zero Bottom Freezer Refrigerator
Problem with refrigearator door.Afer opening it,I can not open again resently. I must wait 4-5 minutes to poen the door again. Can you help me ?
If the humidity is high in your area, the humidity you let in the fridge condenses when you close the door and this makes a partial vacuum in the fridge. This vacuum makes it hard to open the door. After a few minutes, the vacuum leaks and pressure inside the fridge goes up and the door is easier to open. This is normal and no rep are is needed. Just pull harder or wait a few minutes to open. If you really are not able to open it and you need to open frequently while cooking, pull the vegetable drawer out a little to prevent the door from closing all the way and sealing. Make sure you close the drawer and door after cooking or you will have a big electric bill. Another option is to slide a spatula along the gasket to allow air int the fridge when you need to open it.
Jul 24, 2011 | Refrigerators
Refrigerator section light broke. Replacement
Immediately when you open the fridge door the light has to go on,if it is a screw bulb,just tighten it little while'
if pin bulb push it harder,finally you may have to change
the bulb handle in the fridge.
May 12, 2010 | Maytag MTB2176 Top Freezer Refrigerator
Refrigerator door not closing
look at bottom of door. there is a metal bracket called your door stopper. this only allows door to open so far. if pushed open to far then you bent this bracket. bent back to normal position. your door will close
Jun 21, 2009 | Whirlpool Refrigerators
Refridgerator was never that cool now its warm
put a thermometer in the refrigerator and one in the freezer to see what it reads each day when you had the freezer open it it coses it to work harder like having an air conditioner on with the window open it has to work harder to keep it cold so by recording them temp to see if its dropping or it stays the same you might have to get it looked at but for just getting it a week ago it should not have hurt anything just leaving it open a little bit might just be normal for it to be hot i have a side by side and the side is hot but not to hot just warm. let me know hope that helps
Jun 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Refrigerator Model #ED27DSXDBOO
no this is normal, as the fridge works harder it spreads the heat to the ouside of the fridge
Jun 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
