Question about Car Audio & Video
The CD player in my truck
No matter what I have the volume set at on my Jensen mod. CD3010X , if it's at 06 or 34 when I turn the ignition off then back on the volume will go back to 13. Is there any way to correct this without replacing the unit?
    Problem Solver:
  • 6 Answers
Shop, I do believe that model resets the volume when it comes on, its made that way, alot of the factory stereos do the same thing, a 99 ford f-150 for example, I hope this helps
Posted on Apr 18, 2008
My Jensen radio continuously seeks for channels,no reception.model#CD3010X
check to make sure your radio wire is pluged in to the back of your sterio and if it is take it out and clean the metal on it so that it gets better connection
Jul 12, 2009 | Jensen (654658) CD Player
Jensen CD3010X Radio Problems
This happened to me too--with the same unit. I finally took it apart and found that the volume up button was shot. The tiny piece of metal that makes electronic contact had actually snapped in the middle causing contact to be made at random by bumps rattles or just about anything. Since the unit automatically comes on when the volume button is pressed, even turning it off was ineffective. So...I unsoldered one of the buttons that I never used much and soldered it where the broken volume button had been. I'm no expert, so I was rather surprised when the unit worked after i reattached it in my dash. Anyways, it was a cheap fix for a cheap--and poorly made deck. good luck
Mar 23, 2008 | Jensen CD4610 CD Player
How to activate the "LOUD" in my Jensen UV8
customer support suggested this: Turn the volume control, and while the yellow speaker icon is still visible, press and hold the volume control until you here a double beep. This confirms the new volume setting.
Dec 08, 2007 | Jensen VM9510 Car DVD Player
Setting clock
Turn the power on. Push and hold the DISP button. Then use the volume button to change the time.
Nov 06, 2007 | Jensen CM9521 CD / Cassette Player
Turn on volume
If you go to this link and click on "find a manual" http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13668&langId=-1 Page 11 should tell you what you need to know :)
Apr 20, 2007 | Jensen CD4610 CD Player
Volume resets to 26 every time unit powers on
Jensen Units donot remember your previous setting, its just one of the many reasons not to get one
Mar 27, 2007 | Jensen VM9020TS Car DVD Player
Jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Oct 23, 2006 | Jensen VM9410 Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
