Question about Whirlpool Duet GHW9150P Front Load Washer
When the washer spins it makes a banging noise and the plastic around the tub shaves off
Thank you! We took our Duet 9150 apart and found that ALL THREE support arms were cracked. Same problem with shredded front tub also. My washer is a little over 7 years old. I called Whirlpool at the above number (you can't get "warranty service" but the parts service lady transferred me to the warranty dept). They were most helpful, and are shipping me both the metal tub AND the plastic which the metal destroyed, free of charge. Apparently your experience has shown them they have a problem with this...or I got a more helpful service agent!
Posted on Mar 02, 2012
  • 8 Answers
SOURCE: Duet washer very loud when spinning
No you do not have problems with your bearings (especially if you can rotate the basket and it rotates nice and smooth).
What has happened to your machine is exactly what happened to mine: One of the three 'legs' on the shaft support attached to the rear or the basket has broken. The reason it broke is because the bracket is made of die-cast aluminum alloy that is being attacked by galvanic corrosion. See attached pictures of the corroded shaft support, including a close-up of the break. This is what you will find when your machine is taken apart.
You can verify this failure mode by slowly rotating the basket and observing the position of the basket at its maximum off-center location. While the basket is at this position look at the back of the basket and you should see one of the three 'indents' located at the 12 o'clock position. While at this position you should be able to move the basket up and down. Now rotate the basket 120 deg so that the next 'indent' is positioned at the 12 o'clock position. The basket will now be more centered in the opening, and you will not be able to move the basket up and down. You have just identified which of the three bracket arms have been broken.
Call Whirlpool warranty service (1-800-253-1301) and tell them about the problem with the basket: believe it or not the basket has a life-time warranty. The shaft support is not available as a seperate item. The basket p/n is 8182232.
I was able to get Whirlpool to send me a replacement basket, but they would not do the same for the front-half of the plastic tub, which was damaged by the basket hitting the front lip, even though the warranty states that the plastic tub is warranteed for ten years. They did however agree to sell me one for 50% off the std cost. The p/n is 285982.
If your washer was purchased less than 5 years ago, best to work with your local Whirlpool authorized service agent to get the machine repaired. My machine is over 5 years old (GHW9100LW1), and I am repairing the machine myself.
I would be interested in hearing how you make out in getting your washer repaired.
Regards,
Bill in Ma.
Posted on Nov 18, 2008
catriver
  • 878 Answers
SOURCE: Tub and Basket
Fairway, sounds like you have a worn drive block. You are going to have to remove the agitator and inspect the drive block. If it is the drive block you will get some good hammering when the spin cycle stops. I will attach some photos of a worn out drive block. If you want to attempt to handle this yourself, we can walk you through it. Catriver..post back.
Posted on Oct 23, 2006
  • 113 Answers
SOURCE: Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Posted on Jan 08, 2009
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
heatman101
  • 43501 Answers
SOURCE: My washer is out of balance when spinning.
Your problem is probably much more than the washer being out of balance. The front load washers have shock absorbers that hold them from moving all over the place. These have a habit of breaking. Then the drum hammers and sounds like things are flying apart. Pull the bottom front off and check the shocks. Typically the rings where the pins go throuhg are where they will break. Sometimes at first they look okay and you have to grab them and move them to see that they are broken.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 30, 2009
Testimonial: "Thank you. I think this sounds like exactly the problem I'm having."
My ge washing machine is 4 years old and has bee making a loud banging sound while in use it has also bee spouting water from the bottom while washing what advise can you give me to have this fix
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, DRIVE BLOCK, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Another noise issue can arise from a worn SNUBBER RING on some washers that have a snubber like some Maytags, if u notice tiny pc's of white/grey shavings on the floor or around the bottom washer area? A sign of bad snubber. When removing to replace be careful as the spring underneath is pressure loaded.
A very similiar sound can be produced when the belt is worn but the difference is that a snubber noise can be produced during the spin cycle or when the cycle has finished and the spin tub is coasting to a stop. A worn belt noise can only be produced while the motor is actively engaged in spinning the spin tub. If it is discovered that the belt is worn and the base has black, shredded belt residue then it may not necessary to clean it out (belt residue generally will not cause a problem with the snubber). It will be necessary however, to find the cause of the belt failure.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
GRINDING NOISES:
The plastic drive is known as a splutch (splined clutch). One problem with these washers has been loosening of the nut that locks the pulley to the agitator input shaft. If it gets loose, the pulley drops and the teeth no longer have good contact with the teeth of the splutch basket drive gear in spin mode. The solution is application of blue locktite to the threads of the input shaft. There have also been a lot of failures of the actuator that operates the cam ring of the splutch which raises and lowers the basket drive gear. It is raised for agitate mode and lowered for spin. There is a spring between the basket drive gear and the gearcase housing that maintains pressure on the basket drive gear. There are cams on the cam ring that ride up and down on cams in the splutch cam (housing) as it is rotated by the actuator thus raising and lowering the basket drive gear. The gearcase has a planetary gear set in it.
Jan 14, 2017 | GE Washing Machines
Fisher and paykel alba washing machine beeps on spin cycle and makes a banging noise
GRINDING NOISES:
Jan 14, 2017 | Fisher and Paykel Washing Machines
I have a kelvinator K605 top loading washing machine it is very loud when it spins.
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
Jan 26, 2016 | Washing Machines
Banging noise on rinse/spin cycle. Model 23032101
GRINDING NOISES:
Jun 12, 2015 | Kenmore Washing Machines
Estate washer baangs loudly when rinsing dances around o floor...rebalancing doesnt help
Feb 22, 2014 | Estate TAWX700JQ Top Load Washer
Estate etw4400tq
Feb 18, 2014 | Estate ETW4400TQ Top Load Washer / Dryer
Plastic shaving in wash from ring around basket. What could it be. Model GHW9400PW0 Whirlpool Duet
k where they came off from so you can put them back otherwise it will leak. Inspect the inside of the unit while the tub is out (bearings, etc) to make sure there isnt anything else. Hope this helps!
Jan 30, 2013 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Whirlpool Duet GHW9150P Front Load Washer Logo
406 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
