Question about Canon PIXMA MP130 All-In-One InkJet Printer
Can't remove memory card from printer - Canon PIXMA MP130 All-In-One InkJet Printer
    Genius:
  • 1,354 Answers
Hi
  • Ensure the MP970 is connected to a working electrical outlet. Turn the printer on by pressing and releasing the power button located on the upper left hand side of the control panel.
  • Step 2 Select the memory card you wish to use. Insert the memory card into an appropriate adapter if it requires one. Open the Card Slot Cover, located on the right hand side of the printer, by pulling the door out and toward the center of the printer.
  • Step 3 Insert the memory card into the appropriate card slot with the label side facing up. Confirm the Access Lamp is lighted. Close the card slot cover.
  • Step 4 Check the "Select and Print" option on the display screen. Select the "Okay" option.
  • Step 5 Load your preferred print media into the printer. Confirm Paper Source, Paper Size and Media type. Select the "Okay" option. Select the "Next" option. Select the "Okay" option to access the images on your memory card.
  • Step 6 Press the Left or Right Arrow buttons to select the image you wish to print. Press the + or – button to determine the number of copies of this image you wish to print. Select the "Okay" option.
  • Step 7 Confirm your print instructions. Select the Print option to being printing your photos.
  • Posted on Jul 06, 2010
    How do i delete the memory of all my scans and copies on my printer.
    just via the menu bar on your screen from your printer, delete tasks or the menu bar direct on your printer , search here http://www.manualslib.com/manual/236993/Epson-Stylus-Cx6600.html?page=8#manual. greets richard
    Oct 09, 2014 | Epson Stylus CX6600 All-In-One InkJet...
    "Memory Card is write protected" so I can't take pictures.
    remove memory card ... left or right side of memory you will see one little button slide the button down or up... this button is protected your memory..
    May 28, 2013 | Nikon COOLPIX S6000 Digital Camera
    How to connect a printer to a digital camera?
    If the photos are stored on the memory card (SD) in the camera, then remove the memory card from the camera and insert it into the memory slot in the HP printer. You can then print the photos that are stored on the memory card.
    Jun 03, 2011 | HP Officejet 6500 Wireless All-in-One...
    Hi! Im just wondering for what use the (compact flash) memory card is, when installed in a Kyocera Mita FS-1010? (Beside firmware updates)
    Found this in a manual.
    Insert the memory (CF) card into the card slot located on the rear of the printer. A memory card is a microchip card that may contain option fonts, macros, forms, etc. The printer reads the contents of the card into its internal memory when printer is turned on. The presence of this data in the printer memory can be confirmed on the status page printout. For details of available memory cards, contact your Kyocera Mita dealer.
    1 Turn off the printer. Never insert or remove a memory card while the printer power is on. Failure to turn the power switch off will immediately halt the printer with the four indicators turned on. It also could result in damage to the printer’s electronic parts or the memory card. Turn the power switch on again to restart the printer.
    The only thing I have seen it used for (other than firmware) is to store certain info or fonts for forms (ex. tax paperwork or medical).
    Hope this helps.
    Jul 04, 2010 | Kyocera Mita FS 1010 Laser Printer
    "remove all of the memory cards and press select"
    I'm glad the printer's working now. Great job! If you need more assistance, leave a comment and I'll get back to it. Thanks!
    May 07, 2010 | Lexmark X6570 InkJet Printer
    Do I need an adapter?
    The printer has its own slot for a memory card.
    Turn your CAMERA off.
    Remove the memory-card.
    Turn your PRINTER off.
    Insert the memory-card into the printer.
    Turn your PRINTER on, and it should recognize the memory-card.
    Dec 28, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
    Have a HP 2175 all in one. in the front how do I insert the camara memory card ? or is this possible?
    You can only insert a memory card if it is made to be inserted in that printer.
    If yours works like mine, you must remove a blank "slug" before you can insert a memory card. The slug is shaped exactly like the memory card. And more that that, when you remove the slug, you must look at the slug to see how it is orientated. In that way, you can tell how to insert the real memory card.
    Most of them have a corner missing, as if it had been removed, or cut off. If you then line up the memory card to match the way the slug came out of the printer, you can then put the memory card into the printer the way it is supposed to go and that way, it will be "read" by the printer.
    I hope this helps.
    -a.
    This URL will take you to a page on HP's site, dedicated to the memory card:
    http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=2527&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=90809&lang=en
    Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    How do you transfer photos from memory card inserted in HP C5280 printer to my computer?
    You cannot read that memory card inserted in HP printer to your Computer because that HP Card Reader port is only for direct access printing from memory card.
    All you have to do is use a Multi-memory card reader into the PC where connected to USB port.
    I'm sure 100 works!
    Oct 09, 2009 | HP Photosmart C5280 InkJet Printer
    Memory card
    remove the memory card. inspect the card and the slot. make sure the card seated correctly and all the way till it locks.
    Nov 01, 2008 | HP PSC 2175 All-In-One InkJet Printer
    HP Officejet Pro L7680 Problem - memory card reader
    You should see in "My Computer" a few drives that read "Removable disk". They refer to the memory card slots on the printer. Double click on each one until you find the one that your card is in.
    Jun 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
    Canon PIXMA MP130 All-In-One InkJet Printer Logo
    109 people viewed this question
    old marine
    old marine
