Question about Panasonic PT-53WX52 53" Rear Projection Television
Sudden shutdown - Red light blinking 3 times
MY TV just suddenly turned off and now no picture is showing. When i turn it on it stays on for a few seconds and then its turns off and the power light blinks 3x. What could the problem be and what are the next steps i should take?
  • mikaspt May 14, 2008
    some problem here with panasonic tx-42pt10f have sound no image them turn off and red light 3 times. i see the PCB and i only see a faulty solder from a S4 from transformer it seem someone forget to solder that pin.
    if i wait 3 or 4 days them connect it work fine for days them it off again.
    maybe stk fail??
  • 934 Answers
Replace both convergence Ic's Stk392-110 and personally I'd use STK392-150's for greater reliability. Also check all 2.2 ohm 2w resistors for open or change in value and replace as many as needed...
Bill
Posted on Apr 18, 2008
Samsung TV pitch black, no picture. Red light is sold, blinks when attempting to turn on or off.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. .
Aug 18, 2017 | Samsung LN40A650A LCD TV
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
T.v. wont stay on
hello it sound's like you have a power supply problem. need's to be replaced. "good luck"
Aug 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony kdfe55a 20
2 YEAR IS TIME TO RPLECE LAMP
Mar 30, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
No picture; No sound
how many times does it blink red? It should blink so many times then stop then blink again. how manty times does it cycle?
Jan 02, 2008 | Sony KDF-E42A10 42 in. LCD Television
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Samsung 54" Projection TV (PCN5425R)
sears does inhome service, if you do try to fix it, there is usually a board mounted to the back of the tubes (above the others), if it has this convergence board, try unplugging the red connector with the blue wire and turning set back on, if it powers with a 3d looking picture, you have a bad convergence module. Other than that you may want to call a repairman.
Jul 08, 2007 | Samsung PCN5425R 54" Rear Projection...
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Panasonic PT-53WX52 53" Rear Projection Television Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
