Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
We changed the cracked line that was leaking but when we pushed the dishwasher back into position it won't turn. The lever does close but could this be out of alignment?
Lever on GE Nautilus dishwasher won't close or lock
This is not a question. Do you have a question?
Aug 26, 2012 | GE Dishwashers
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
1989 Honda gold wing 1500 // I am two days into my vacation and am loosing clutch lever resistance and there is fluid under the triple tree. Thane anyone don
Sounds to me like you have a leak in your hydraulic clutch system. Your clutch lever will start to feel odd as (1) fluid leaks out, reducing pressure; and (2) less pressure reaches critical areas because pressure over a certain level is squirting fluid out of the system.
Leaks like these are often caused by one of two things: (1) a hydraulic line that has sprung a leak; or (2) a leaking / cracked fluid reservoir on your clutch slave cylinder. I am discounting the possibility that the slave cylinder itself is going bad, as that wouldn't create fluid leaks external to the system.
To troubleshoot your system, top off the fluid reservoir and then squeeze the clutch lever repeatedly while looking closely to see where fluid may be leaking out. MAKE SURE YOU'RE WEARING GLASSES OR PROTECTIVE GOGGLES WHEN YOU DO THIS!! A pinhole leak in a hydraulic line can shoot out a thin but forceful jet of fluid, and that's really nasty stuff to get into your eyes (it's bad enough on your skin or on the painted surfaces of your bike). The leak won't dribble all the time, only when you're applying pressure, which is why you'll need to keep working the clutch lever while you're looking for leaks. The location of the leak will tell you a lot.
Though I can't see your bike, I'm leaning towards the idea that a hose or, more specifically, the metal end of the hose, is leaking fluid under pressure. If this is the case, you should be able to obtain a replacement hose/line from a Honda dealer and swap it out without too much of a bother. If you're in the middle of nowhere and can't get to a Honda dealer, it's also possible that a hose shop could fabricate a custom line for you if you're able to show them your old hose.
On the other hand, if you have a cracked reservoir, you most likely will have to replace the entire clutch actuating assembly (slave cylinder? clutch cylinder?). That part should be relatively exposed--it may be mounted to the handlebars out in plain view; you won't have to mess with the actual clutch inside the transmission. Because of the location where fuel is puddling, though, I think this is less likely than a hose / hose connection problem.
Good luck, and I hope this doesn't spoil your vacation!
Jul 25, 2011 | 1989 Honda GL 1500 Gold Wing
My clutch reservoir is empty of fluid. I believe there is air in the lines, how do I bleed the line and where is the nipple to do the bleeding?
okay..I replied to your other post on the bleeder...but anyway...right behind the base of your left rear cylinder is a square rubber flap...lift the flap and the flap is teethered to the bleeder nipple.
Okay....add fluid to reservoir....be aware dripped brake fluid will destroy paint, fairing plastic etc...so have a pail of warm sudsy water to cleanoff any spilled fluid ASAP.
Replace lid ....attach a hose to bleeder nipple to a waste container. Pump the lever slowly a few times.....then pull lever partway in, and crack open the bleeder.....slowly pull lever in and hold...close bleeder. release lever. Pump lever ....hold partially in...crack bleeder....pull in , close bleeder, release bleeder.
Add fluid as needed to reservoir.
Never release lever with bleeder open or you will draw air back into bleeder from hose...always close bleeder first.
Continue this till clear new bubble free fluid exits the bleeder.
Refill reservoir leaving some room for expansion as the fluid heats up. Reinstall cap.
Aside from an obvious line leak....main cause of fluid loss from clutch reservoir is the slave cylinder seals are weeping....should consider rebuilding or replacing the slave...about $70 for a new slave.
Apr 13, 2011 | 1996 Yamaha Royal Star XVZ 1300 A
How do I reset the combination?
Open the lock with the existing combination. Inside the outer panel, you will see a small lever that will push to the right, and **** in an upward position. With the lever cocked in this "learn" position, turn each wheel to line up the number you desire with the scribed line. Once all four wheels are parked on your chosen combination, flip the lever back into its "home" positon. Test the new combination a few times (and record it somewhere safe), before you close the lock up.
Dec 31, 2010 | Master Lock 5400d: Portable Select Access...
Dishwasher leaks from bottom
You must first determine exactly where the water is coming from. The water supply line may be loose or cross-threaded. The overflow float may be stuck in the down position. This will allow the machine to over-fill and leak. The door seal may be worn or off-position. The drain line may be loose or have a hole in it. The wash tub may have a crack in it that needs to be sealed. A gasket around the motor or the heating element may be loose or split.
Get a flashlight. Remove the bottom panel. Start the cycle. Get comfortable on the floor and watch closely. This may be a simple fix. Something like tightening a loose hose. Good luck
Dec 04, 2009 | GE Nautilus 24" Built-in Dishwasher
My dishwasher doesnt start
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Apr 22, 2009 | Ariston Technologies LL64WNA Built-in...
Door latch in closed position
put two small screwdrivers in each side of the latch and lever upwards (best way) or otherwise take the door outer panel and fascia off so you can get at them
to stop it reoccuring, bend u catch on cabinet slightly downwards
Jul 20, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
Leaking icemaker
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
Oct 29, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Leaking on floor only after shuts down.
Griz, check the vent and see if you have bunch of gunk thats collecting water in it. Sometimes the spray arms are cracked and direct water into the vent. If this happens you will have leaking down the center of the door. Catriver...post back
Aug 14, 2006 | Kenmore 18 in. 14432 / 14439 Built-in...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
