How to set up port forwarding on a Netopia router serial number 33476304
    Novelist:
  • 150 Answers
Logi into the router using a WEB browser, and look for things like NAT (Network Address Translation) , Virtual server, or firewall settings
Posted on Apr 18, 2008
How to port forward on Netopia 3347WE
1. Click the Expert Mode link near the left of the page.
(it is not listed in the manual)
2.Click the Yes, enter expert mode button near the centre of the page.
3. The menu on the left should change. In this new menu, click Configure.
4. You should now see a new menu. In this new menu, click NAT.
5. Click the Define Custom Service button near the center of the page.
6.Put a dot into the Port Forwarding: Range of Ports radio button. 7. Click the Next button. Then set up the ports you want to forward. One Example s here
O
Port Forwarding the Netopia 3347W Router for Xbox One
Mar 15, 2015 | Netopia Computers & Internet
Netopia 7000 router
try this website out they have just about every router out there listed Port forwarding the Netopia 2247NWG VGx router
Mar 14, 2014 | Netopia Computers & Internet
Xbox360 live setup
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
HOW TO FORWARD PORTS 8090 AND 37766 TO SPECIFIC IP ADDRESS
Go to this web site and follow the instructions.
These instructions are specifically for your router and a host of different apps you can forward the ports for
http://portforward.com/english/routers/port_forwarding/Netopia/2247NWG-VGx/2247NWG-VGxindex.htm
Jan 18, 2011 | Netopia 2247NWG-VGx Wireless Router...
How do i forward a port i want to play call of duty black ops but i cant find an online game, the game website says to forward these ports, TCP [80] UDP [88, 3074, 22728, 33233] but i dont know how to...
http://www.netopia.com/support/hardware/technotes/NQG_025.html
Server List (Port Forwarding) NQG_025 With NAT enabled, the IP addresses of nodes on your LAN are private since they are hidden from the Internet. IP Servers let you pass specific types of network traffic through the Netopia router's NAT interfaces. Once configured, selected types of network traffic, such as FTP requests or HTTP (Web) connections, will be forwarded to a specific host or server behind the Netopia router. Please Note: From the LAN (Local Area Network), you will also be able to access the servers that are responding to requests from the internet, but only using the internal private IP address. Access via the public IP address is not supported from a local ethernet connection. If your ISP is routing you multiple public IP addresses, you can also configure the router to forward all ports in one public IP to a designated private IP address on your LAN via Easy PAT List entries. For those instructions, see Quick Guide NQG_024: IP Mapping (Address Forwarding).
Please Note: If your router is currently running Netopia Residential Firmware with a web "GUI" configuration menu, this technote is not applicable to you. Most 3300 Series Netopia Gateways can be upgraded to Enterprise level firmware. Click Here! to purchase the upgrade key.
Related documents: NQG_039 NAT and the Basic Firewall
Firmware References:
  • v8.2 R1 (and up) - 3300 Enterprise Series
  • v5.3.7 (and up) - 4000 Series
  • v4.8.2 (and up) - R-Series
Before You Start
Telnet into the Netopia router's Main Menu at 192.168.1.1 (if using the default IP setting). If your network has a different IP addressing scheme, modify this accordingly. Click Here! for instructions on using telnet and Hyperterminal (serial connection).
Login with the user name and password. The Superuser login is required to save changes. If you are unsure of this, contact your network administrator.
Don't forget to press the Enter key to save any entries. Hitting the back space, delete or tab without first hitting enter will undo any changes.
The Esc key will take you back towards the main menu screen.
Once you have completed your configuration, you should reboot the Netopia to save and apply your changes.
The Netopia Main Menu Interface
Server List Configuration
  1. From the Main Menu of router console screens, go to Quick Menus, and select Network Address Translation.
  2. Select Show/Change Server List.
  3. Select Easy-Servers.
  4. From the Show/Change NAT Server List screen, select Add Server.
  5. Select Service and the service and port you want to allow. If your service and port are not available in the pull-down menu, select Other. Selecting Other will allow you to enter a specific service port or a range of ports since fields are provided for both a First Port Number and a Last Port Number. To allow a specific service port, the First Port Number and Last Port Number should be the same. Select Okay.
  6. Next, enter the Server Private IP Address, or the private IP address of the host/server you are forwarding the service to, and the Public IP Address you want to associate with the same host/server. This value can be left set to 0.0.0.0 if you are using the WAN IP as the Public IP address. Note: If your ISP is routing you multiple static IP addresses, other then the one used for Internet access, you may create more than one server for specific service as long as all servers have a different Public IP Address specified. For example, with two web servers on your LAN you would need to create two Server List entries for TCP 80 (www-http). Since each specific port (service) can only be mapped once using any given Public IP Address, a distinct public address must be used for each TCP 80 server list entry. It is not necessary for you to specify more than one Local WAN IP Address or Public IP Address in your router's configuration. As long as you are connecting to your ISP via a public IP address used for NAT, they are responsible for routing all other IP addresses via that connection.
Conclusion
You have now configured your router for TCP/UDP port forwarding. If you have a switched connection (ISDN or Analog), you will need to either disconnect and reconnect your Internet connection, or restart your router for the Nat Server List changes to take effect. If you wish to filter traffic for your static IP mappings, please see the following Netopia Technote:
NQG_039: NAT and the Basic Firewall
Nov 12, 2010 | Netopia CAYMAN 3387W-ENT CABLE/DSL...
Netopia NAT
I know that most Netopia's I've worked with have been able to port forward single or ranges of ports to numerous internals from numerous externals.
Address Translation needs to be on.
IP Passthrough has to be off.
Then in NAT Easy Servers, setup port forwards and specify the external IP, internal IP, and ports (can forward all).
Dec 21, 2009 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
Ps3 setting up static nat
are you in ireland and with eircom?
Feb 19, 2009 | Netopia 2247NWG-VGx Wireless Router...
Netopia routers2247NWG/slow download speed/
Actually the application may be games or any other software which it setted port is not open/accessable through your router and it will work by default ports and the speed or the performance is very slow- Try to configure proper port forwarding according to the application port settings check those ports are open after configuration
Hothawk
Jul 14, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
