Question about Sylvania Televison & Video
I am looking for a certain vcr ;Model no.6260vc,SE no. u3221867
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Check ebay
Posted on Jul 16, 2010
How do I unlock region codes on a Toshiba SE-R0220 DVD/VCR player? I've tried many codes for other toshiba DVD players but none of them work :(
The Toshiba SE-R0220 is the REMOTE model number not the DVD/VCR model number!
You need to find hacked firmware for the DVD/VCR model number you have that releases the region settings.
Write it to a CD RW or DVD RW disc and follow the instructions for updating the firmware.
There is a chance that the firmware will not update correctly and you'll be left with a DVD part of the system that doesn't work.
Nov 03, 2016 | Toshiba Televison & Video
VCR stops recording by itself after a couple seconds.
Some VCR's will stop if the signal is not there. Retune the set if it uses Freeview. The broadcasters and those who are in charge of Transmitters like to mess around with the stations from time to time. This will effect the recording if you are using a model with the Guide Plus system. If you are timer recording it make certain that the settings are good. If it is an older model, make certain a thing called PDC is not on.
Dec 16, 2015 | Panasonic PV-7450 VCR
I cant get the remote to work for Symphonic VCR Model SL6820 and I need it for the menu
If the batteries are good then sometimes it's the VCR that is faulty. If NO buttons work at all on the remote, this might be the problem.
Make certain the remote sensor on the VCR has been blocked.
Aug 11, 2014 | Televison & Video
Analog VCR Model SDV394SU on cable will tune stations and record the current station, but will not start for for programmed (on/off timed) recording. In other words, when you program the VCR to start at a...
The answer to your question, "Does this have anything to do with the fact that the VCR and TV are now on cable?" is no.
The outside antenna and the cable are input signal sources only and have no effect on the functions of the VCR.
It sounds like you have an electronic problem with the timer circuitry. In order to locate exactly where the timer circuitry is located, you would need a service manual for your particular VCR. Using the service manual, you may or may not be able to repair it.
My suspicion is that it would be cheaper to just purchase a new VCR if timed recording is important to you.
Aug 07, 2009 | Toshiba Televison & Video
Magnavox TV/DVR/VCR Combo Model 20MC4304/17 color out
tengo un televisor magnavox combo pero so;o quiero sabersi se puedde dejar solo funcionando como tv ...y eliminar dvd . ya que no puedo hacerlo.
alguna ayuda se la agradeceria
Feb 03, 2009 | Philips Magnavox 20MC4304 20 in....
Dejar solamente la TV
you have a Philco, TV\VCR Combo Your problem is the VCR.The rubber band that pulls in the Vhs tape and kicks it out is stretched,
or damaged. The TV turns off to protect itself. You need a replacement.If u know how to get inside,look at the right side of the VHS section [you will be facing the back of the TV] be careful! "Electricity HURTS. It will be very hard to find the replacement VHS rubber band. There are 3 bands, replace them ALL!!, not just the damaged one.
Apr 25, 2008 | Symphonic SC3813 13 in. TV/VCR Combo
My tv keeps turning off after 5-10sec.
Hello Onna76,
Ok this is a VCR/DVD Combination TV. First of all let's look at what your description says: "The VCR part has been removed" dou you mean that the VCR mechanism has been taken out or do you mean that the VCR mechanism was removed and then put back in? The reason I ask is because on the VCR circuit board there is a position sensor which senses the position of the gears on the VCR mechanism, when the gears are positioned in a certain way the sensor tells the power supply to remain on, however if there is a misalignment the set shuts down. This is what is happening in your case. If the VCR mechanism was moved and then replaced, make sure that the sensor and gear are aligned properly. the protrusion on the sensor should go into the grove on the gear and the middle of the gear should go into the middle of the sensor. This will allow the sensor to track the gear and take care of that cutting off problem.
I hope this helps,
Thank you,
Shuttle83
Mar 03, 2008 | Televison & Video
VCR Won't Record Sound
Some VCR have the ability to record sound from another source. Check the sound settings and record settings to make certain it has not been switched to another sound setting.
Oct 03, 2017 | Televison & Video
Zenith TV/VCR Combo, Model TVA 1923
Go to Radio Shack and get a basic universal remote, about 10 dollars. Once you program the tv with the remote you will be able to get all of the channels. The workers at Radio Shack are very helpful if you have any problems.
Oct 13, 2006 | Zenith TVBR2742Z 27 in. TV/VCR Combo
Televison & Video Logo
21 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
