Question about SaniServ 501 Twist 22 Quart Ice Cream Maker
I had a motor rewound for my 501k saniserv icecream machine. The motor company put a new style board in it different than the original. My question is 3 wires that come from the top of the machine black,green,white go to what parts of the machine as to tell me where to hook them up on the motor.
  • TY ZELLMER Jul 08, 2010
    the green is not ground it goes up to the circut board not not sure what one. the motor has a seperate ground to the frame itself
    Genius:
  • 1,040 Answers
Green is always earth. As for the black and white, It differs depending on what country you are in. In Australia, white is usualy a switched active and black is neutral. But in America, I believe that the black is active and white is neutral...
Now check the motor's connections point and put the cable... Fi you are not skilled enough and If possible then take the help of local electrician. Don't play with light. wrong wiring can burst the motor...
Hope this has helped you.. Thanks...
Posted on Jul 08, 2010
  • SaniServ Master
  • 15,557 Answers
White is nuetral, black is hot and green is ground.
Posted on Jul 06, 2010
  • Brad Brown Jul 08, 2010
    IF this is USA and not a different phase then green has to be ground . Code says that you cannot rely on a frame ground on a device like this.
I need to know the price for a saniserv model 401
Original price brand new is 9,035.00 but now its on sale for 5300.00 Hope this help if you have the manual to this machine can you email it to me amandalairmore@hotmail.com thank you
Amanda Lairmore
Aug 17, 2011 | SaniServ 407 10 Quart Ice Cream Maker
I loaded the machine with mix and turned it on but machine keeps on turning but mix is still very watery
My small Business had this same problem. The first thing you need to look at is the product you are using. It turns out that if you are making your own soft serve. which Includes water and powder, it will save you a lot of time and stress to switch to cartons of soft serve that you just pour right in. It turns out that there is no consistency in powder icecream. the water will eventually separate from the mix, resulting in watery soft serve once dispensed from the machine. Next, if this isn't the prduct you are using then it can be other problems such as your compressor not working, or turning on when it's suppose to, maybe you have a weak motor, or your machine isn't set to the proper freeze level, Also, make sure that your machine isn't backed up against a wall or I between two other machines. These machines need to Obsorb cool air in order to work properly and not overheat . The machine's fan, which is located on the right side, needs to be have a certain amount Of space from walls or other machines. If this doesnt work you can always call a technition to come and check out the machine, I hope this helped, best wishes with your repair
Jul 16, 2011 | SaniServ 401 20 Quart Ice Cream Maker
I HAVE A TOGGLE SWITCH ON THE BOTTOM OF MY MACHINE. WHATS IT FOR???
I have been unable to locate the toggle switch in a SaniServ Operational Manual located HERE , I suggest you call and ask Saniserv what this toggle switch is for 800-733-8073
Thumbs up if this helped!!!
Jun 21, 2011 | SaniServ 401 20 Quart Ice Cream Maker
I have a saniserv 707a and the product won't freeze. The refrig line is freezing right after compressor switch.
my saniserve ice cream machine will not get freeze hard or freeze when u press the button on for the compressor to kick , it will not kick in.
May 12, 2010 | SaniServ 401 20 Quart Ice Cream Maker
Same Machine
In the 1990s SaniServ manufactured soft serve ice cream makers for slush puppy Corporation and call it freeze bee model A 501 which is the same machine as SaniServ model 501...........
if you go to www.saniserv.com or call their phone number at 317-831-7030 and give them your serial number they will give you all the information you need, when inquiring ask for technical help.
I have one and I really like it, does a great job, you need to fine the saniserv dealer closest to you for parts and supplys, they have everything you need.
Bob aviator state of Maine
Aug 31, 2009 | SaniServ 501 Twist 22 Quart Ice Cream...
Press the switches and nothing turns
Contact the manufacturer.
This sounds like something that you may have to get repaired (or, if not, the manufacturer usually knows all the little tips and tricks to get it working! :)).
Their contact number should be either stamped somewhere on the machine or in the product manual (usually near the back of the book). If you still can't find it, you can usually just do a quick internet search (just typing in the manufacturer name--in this case, "SaniServ"--and then "support" into Google usually helps).
Good luck! :)
Aug 22, 2009 | SaniServ 407 10 Quart Ice Cream Maker
I need a manual
Couldn't find a manual for you.
But i found a link to SaniServ to contact them for techincal support:
http://www.saniserv.com/contact.jsp?p_=&go=no&form=4
Hopefully they can tell you how to fix your machine.
Good Luck
Apr 16, 2008 | SaniServ 501 Twist 22 Quart Ice Cream...
SaniServ 501 Twist 22 Quart Ice Cream Maker Logo
51 people viewed this question
Top SaniServ Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you a SaniServ Ice Cream Maker Expert? Answer questions, earn points and help others
