Question about Curtis Lifestyle DVD System
Dvd player picture flops non stop, it's not the cables or connection.
  • tkretro Apr 18, 2008
    The picture flops when you turn it on the curtis logo moves top to bottom. Same problem with a dvd in, I tried several dvd's, all these dvd's work on other players. This is a cheap player but you should be able to use it more than once.
    President:
  • 1,944 Answers
Does this happen all the time? Or is it with specific discs?
Posted on Apr 18, 2008
How do I turn off pscan on a rca dro2oon DVD player
IMPORTANT:
If you don't have a Progressive Scan TV or you don't have the DVD player connected to the correct Input Jacks, and you activate Progressive Scan in the DVD player you won't see a picture! Don't panic-try the following:
First, press the PREV/VIDEO button on the front of the DVD player (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If that doesn't work, press and hold PREV/VIDEO button on the front of the DVD player for 3 seconds. Now, press the PREV/VIDEO button again (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If you still don't see a picture on your TV screen, make sure the yellow cable (provided) that is attached to white and red cable (called audio/video cables) is connected to the DVD player's PREV/VIDEO jack and the TV's Video Input jack. Change your TV channel to your TV's Video Input
channel that activates the TV's VIdeo Input jack where you have connected the yellow cable (page 9 of your manual has more information).This PREV/VIDEO jack on the DVD player always outputs interlace video, so you should see a picture on the TV screen.
As a last resort, you can reset the DVD player to the factory default settings:
Press and hold the STOP button on the remote control and the NEXT button on the front of the player at the same time - wait at least 5 seconds before you release both buttons
Sep 25, 2016 | RCA Televison & Video
How do I connect my Samsung dvd-vr recorder to my non HD tv
Hello
Use an AV cable, connect the devices in between that cable to appropriate input sockets, select the input of your tV to AV. Picture of AV cable is attached.3_9_2012_2_26_16_am.jpg
Mar 08, 2012 | Televison & Video
Bought H1080/XEU dvd player - have Sony 1080 TV - are they compatible? Picture keeps stopping for few seconds and then resuming.
Looks like it is the problem with the DVD disc / media source. Replace the disc with another disc. Last but not least.. why dont you try connecting the DVD player and TV via HDMI cable? Sometimes older cables may cause video drops .. just guessing anyway!.
Mar 05, 2011 | Samsung DVD-1080P8/XEU DVD Player
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
When connecting dvd to hitachi 42hdm12a, screen said something was corrupted. Now, can't get picture. HDMI searching but won't get picture. help
1.Press [stop]button on DVD player to Stop DVD Playback
2.Press the [resolution] button on the DVD player.
3.change resolution to 480p
if you get a picture in 480P, continue your setup of the DVD player
If you still have no picture perform the next steps (stop at the step if you recieve a picture):
4. verify the video input of the DVD player to the TV and reselct it on the TV
5. use Video cable to verify the DVD player is still working
6 disconnect/reconnect HDMI cable to TV
7. power off/on the TV
8. power off/on the DVD player
7.
5. turn off TV then Tunr
Jun 24, 2009 | Hitachi 42HDM12 42 in. Plasma Television
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
Distorted picture after stopping a dvd
How are you devices connected, in what order and with what cables?
Dec 27, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Curtis Lifestyle DVD System Logo
27 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
