Question about iLO Televison & Video
I can't turn it on. red light comes on but green light won't
  • 1 more comment
  • jwigsten Jul 06, 2010
    I'm sorry but Ican't fix apower board..it was working the day before the next day i turned it on the picture and sound would not come on.I checked the power source and cable all ok.
    except taking it in to a dealer I'm 85 with no car. but thanks anyway jwigsten
    can you tell me the name of the fuse, and where the locations is for that part.?
  • 10,865 Answers
Hello. Most likely you have a blown fuse. Take your flat screen into a tv repair shop to save yourself a huge house call fee. J.
Posted on Jul 06, 2010
  • 11,896 Answers
That would likely be a power board failure. If there is no power inverter in this model, which I don't believe there is.
  • Nate Stansfield
    Nate Stansfield Jul 06, 2010
    The power board is the one that has the plug-in attached to it. There should be a fuse on this board as well.
  • Nate Stansfield
    Nate Stansfield Jul 08, 2010
    The power board is the board that is attached to the plug-in cord for power. There may also be a fuse attached on this board. It would be a glass bus fuse. It will have a printed number on the metal end of the fuse.
5 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
  • 141 Answers
SOURCE: when I turn on my
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
Posted on May 05, 2011
SuperTech-11
  • 1591 Answers
SOURCE: My viera th42px600b won't turn
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Jul 21, 2011
protvrepair
  • 153 Answers
SOURCE: Heard a pop , bulb blew out , replaced bulb , it
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Posted on Oct 29, 2011
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
My Wii won't turn on! :(
some one is turning it off or becuse you were sitting on a wii remote.
Apr 07, 2013 | Nintendo Wii Console
When in turn on the playstation 3,red light is on and of i try to touch the sensor to make the red light into green but within a few seconds green light turns into orange and becoming red and the red light...
This is a common occuring problem what has happend is you have the ylod better known as the yellow light of death. This means the solder on the motherboard has come loose and won't supply the needed power to keep the system running so you need to either send it in for repair which is $110. It's gone for two weeks then back just as good as new
Oct 12, 2012 | Sony Playstation 3 (PS3) Console
My tv the light is flashing red green an won't
replace the power supply board. You can get replacement power supplies from www.tvcircuitboards.com
Mar 07, 2012 | LG Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Televison & Video Logo
19 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
