Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
Water shoots out of chemical injector hose on pressure washer
2 Suggested Answers
  • 2428 Answers
SOURCE: Power washer starts, water to washer on but no
this with the engine running? If so there eigther is a restriction in the main water feed or the pump is damaged or possibly needs to be rebuilt. Did you know you can never start the mechine with the water hooked up and on full and you should trigger the gun to force the air from the water pump before you ever start the engine. Is it a mi-t-m pump or a cat pump. The mi-t-m pumps have a problem with the plastic cages that hold the valves braking and getting stuck between the valve and the valve seat if you take the caps off the pump you can pull the peice out and the mechine will work again. The cat pumps have cremic pistion and if over heater need to be rebuilt but is a vastly better pump and if maintained wil last 25 to 30 years under heavy use
Posted on Dec 08, 2010
The pressure washer will not syphon chemical, the hose and filter are clear and it still doesn't syphon. there is a fitting at the bottem of the line that constantly has water coming out that may...
Use the blacks nozzle to get soap.
but if water is coming out from the soap hose then the injector is bad.
i will need your model #
Sep 29, 2014 | Garden
I have a campbell hausfeld 2450 pressure washer with water coming out of a brass hose nozzel right next to where you screw the high pressure to the pump as soon as you turn the water on from the house,...
this is called the chemical injector which enables you to insert the hose for you to dispense the soap and or chemical by utilizing a soap nozzle .apparently inside this barb you will find a ball a spring and a o-ring,find the replacement parts or kit from its manufacturer.finding a plug to replace it is not recommended due to the fact that the pitch of thread is hard to find.replace asap this unit relies on trap pressure to unload.
Aug 04, 2013 | Campbell Hausfeld Garden
Soap dispenser not working
chemical injector activates only when low pressure is utilized try this remove hose from triggergun assembly with the water turned on engine off allow water to free flow out of hose remove the chemical hose from the barb located at pump with a paperclip or needle insert it into the hole of barb and slowly separate the ball inside the barb you should here it siphon and try not to look directly at the port you may get sprayed once freed reinstall all back together and try again.;0;0
Aug 02, 2013 | Karcher Garden
Husky HU 80522 pressure washer - some pressure to the spray gun. water coming from the pump goes straight to the sifon hose used for detergent. Can this line be clamped of if not used?
This unit has a Faip pump on the unit, no water should come out the chemical injector. The chemical injector can be closed off with no problem by installing a plug where the chemical injector hose bard is currently located.
You can also replace the chemical injector, here is a link to view the part.
www.allpartsinc.com/ProductDesc.aspx?code=KTRI91351
Mar 29, 2012 | Garden
Troy bilt 2600 psi when you turn the water on it shoots out through the chemical supply inlet
My chemical supply inlet has a checkball and a spring that keeps pressure in check. There must be debris behind checkball. Easy to check by removing the fitting. If faulty and parts not available, plug fitting and add an aftermarket injector from www.pwmall.com. that you can install when you need it. Good luck
Sep 30, 2011 | Honda Black Max 2600 PSI Pressure Washer
Craftsman Pressure Washer 580.752160 reagent/chemical not being dispensed when wand in low pressure position.
It is very common for the chemical injector valve on these to get gummed up from residual soap sitting in the valve. To clean it follow the chemical hose back to where it attaches to the pump. There will be a hex headed hose barb attached to it. Remove the barb from the pump. Underneath it you will find a spring and a ball bearing. Rinse the parts thoroughly and reassemble. You should also check the chemical strainer that goes into your chemical bucket. They can also become clogged and should periodically be cleaned.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 07, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
I recently purchased a northstar 4000 psi pressure washer. I had the same series pressure washer for the past 6 years and used a downstream chemical unloader quick connect to pull chemical. I attached it...
The injector might be worn out or have something inside of the valve causing it not to ****. If you are using a new high pressure hose or a longer hose this may also have an effect over the injector not working.
Oct 06, 2010 | Northstar Professional Series Pressure...
Genrac power washer chemical injector not working
How long is your high pressure hose and what diameter as it maybe to long and won,t **** chemical due to back pressure. To test this remove the high pressure hose and run the machine and check too see if any chemical is coming up the pipe. If it does then its a problem with your hose or the adjuster is not going to low enough pressure.
Jun 04, 2010 | Garden
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
228 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
