Question about Fisher and Paykel Fisher & Paykel Washer
Fisher& Paykel Smart Drive starts filling with water ,stop and starts then starts beeping with rinse light flashing have cleaned filters etc this even happens when I go to spin
  • bemmettr3 Jul 06, 2010
    Thankyou so much for your help I can fix this myself with a new part
    President:
  • 1,554 Answers
The flashing of the Rinse LED, third LED from right of the Wash Progress LEDs, indicates error code 04 which means the Motor Controller Module has difficulty communicating with the Display Module. Unplug the machine then remove the 2 screws from the rear of the console then raise the console for access to the connection between the Motor Controller Module and the Display Module.
Check the connection between the two and make sure the connectors are corrosion free and sit snugly on the terminals. Reseat the connections several times to clean off dirt and corrosion build up in the connectors and terminals. The Motor Controller Module needs replacing if the connectors are clean and snugly connected to the terminals but the issue keeps on recurring.
Posted on Jul 06, 2010
  • 2 more comments
    I opened the console and every looks to be ok all very clean ,How do I reseat the connections?
    Also how much would a new motor controller Module cost if it needs replacing?
  • Jahn27
    Jahn27 Jul 06, 2010
    Reseating is simply disconnecting the connectors and reconnecting them several times. The Motor Controller Module cost about $180 to $200 and you can purchase it here.
    I have done everything you have suggested and still not working are you suggesting even with a new mudole the problem will reaccure? new machine? Thankyou for help
  • Jahn27
    Jahn27 Jul 06, 2010
    Let me put it straight, the Motor Controller Module needs replacing if the connectors are clean
    and snugly connected to the terminals but the issue keeps on recurring. That is, replace the Motor Controller Module if the problem is not addressed after all the suggested actions has been done.
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
ginko
  • 19396 Answers
SOURCE: Fisher & Paykel smart drive
It is either the inlet valve or the pump. If the pump is fine you need to replace the inlet valve. Here you can find parts.
Posted on Jun 08, 2008
hattonhall
  • 349 Answers
SOURCE: fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
Posted on Oct 19, 2009
sonicboomele
  • 1557 Answers
SOURCE: My fisher and paykel smart drive starts &
just below the wash tub there is a very sensitive sensoer over time it builds up with dust and at the ends youl find slite corrosion clean the sensoer and it will be fine also clean any rust of the capstan rim for more detailed instructions feel free to email my company sonicboomelectronics@hotmail.com
Posted on Apr 21, 2010
caroldon
  • 17130 Answers
SOURCE: My fisher & paykel smart
Possible that the program controller is faulty and is not executing the output when the wash cycle and the drain is done. So the program must advance further to the next stage to drive the motor to spin after the water is pumped off and the water level sensor is reset.
Have the conttroller checked to confirm the fault, look for loose joints in the connections.
If not the controller can be a suspect.
Posted on Oct 15, 2010
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel Kelvinator Smart Drive 601. Machine does not complete full cycle. Stops at most stages and beeps. Seems to have trouble with water intake. Hoses have good water pressure when...
the magnetic switches may be warn. in hard water areas they can block up and stop working. you may need to change them or take them out and stick them in some vinaga and see if it will soffen the hard crust off the inside of them out.
Oct 06, 2013 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
May 27, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
The lights come on, but the machine doesn't start
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
May 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
My fisher and paykel smart drive starts & fills but as soon as it trys to wash, the tub slightly goes round then it starts error beeping. I tried to spin it, it will rinse but not spin does the same...
Apr 21, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
102 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
