Question about Garden
My lawn mawer is not starting. I have checked everything. Everytime we start it alway very hard, this time I give up, i don't know why? please help
  • Ian Summerfield
    Ian Summerfield Jul 06, 2010
    have you renewed the spark plug,cleaned out the air filter,cleaned out the fuel tank and put fresh fuel in,see if carbie loose on its screws,done a compression check[even with the decompression systems on some motors,youll get something],check the piston is at top dead centre,,then see if flywheel magnet lines up with ignition coil
    Sniper:
  • 56 Answers
Check to see if there is water in your fuel tank or carburetor fuel bowl and clean....check float and needle in carburetor to make sure they are working properly.....remove plug and clean, remove all traces of carbon or gummy residue, re-attach plug wire and ground base of plug to cylinder head...pull start handle a couple of times to see if you have spark... if not you may need a new magneto or points and condenser...if spark is good (blue spark) re-install plug and prime the carb with about a tablespoonful of fuel...pull start handle and mower should run...if it only runs for a few seconds and quits....you may have to rebuild the carburetor. also remove the muffler and check to see that the exhaust ports are not full of carbon. Good luck !!! ;-D
Posted on Jul 06, 2010
Craftsman Briggs & Stratton lawn machine engine 6.75HP don't start no spark
Take of the hood and shine up the magneto and if that don't work the take thecarbrator of and where the primer ball is unscrew the Philips head screws and that will release the primer from the gas tank and there will be a little screan blow that out then put it all back together push the primer button 3 times the pull the cord to start the mower and it will run if that don't work then let me know if you want to get ride of it please because my hobbie is working on mowers thnks please respond back thanks hope this helps you problem
Apr 19, 2013 | Garden
Tip
Hard to start Atv ?
Dont always trust a spark plug that gives spark,(it might be a weak spark). Happen to me!! checked everything but didnt want to start, there was fuel,spark and everything seems fine but NO LUCK. Next day fitted new plug and it starts at once.
on Aug 22, 2013 | ATVs
Toro choke doesn't work
try cleaning out the carburator.
May 23, 2017 | Toro Lawn Mower With Toro Power Tools
Not starting
does the starter actually turn the engine everytime or nothing at all sometimres?if it fails to tirn ovewr sometimes, it could be the bendix in the starter, or the solonoid switch ,sometimes its in starter sometimes its under hood
Nov 12, 2011 | 2005 Saturn ION
Hi, everytime i turn on my laptop (dv4000) and start using the keyboard it gives me an error tone and that's it it goes wild.The only solution is to restart the computer and use external keyboard...
When a battery will not start a vehicle, it tends to be in the circumstances most embarrassing and frustrating, a school run by a meeting or even work urgently. Call for help from vehicles is not always an option and even if it may take some time to arrive. Rather than leave it to chance, many drivers now carry 85wh apple A1172 Charger for use in such peril.
Nov 15, 2010 | HP Pavilion dv4000 Notebook
I replaced my cylinder head gasket.after putting everything together,i tried to start it but it won't.it cranks and backfires. i double checked everything and timed it several times by positioning the...
well try removing the distributor and spin it around half way 180 degrees then try. it seems you are off there are two ways to install the distributor because two turns for the crank equal one for the distributor.if still wont start call on me again i will help you .
Nov 14, 2010 | 1998 Chevrolet K1500
My yard machine wont start, i have spark, fuel, and compression. yes there is gas in it. has oil. starter cranks and I pulled the carb off and cleaned the float and everything. the starter almost looks...
Probably not the solenoid they usually work or they don't. Slow cranking could be due to weak battery or bad connections, check those. If all is ok starter motor could be bad. Always check simplest first.
Oct 06, 2010 | Yard Machines 155 Torque Briggs Stratton...
Lawn mower fires but doesn't wanna run
You may have to inspect the woodruff key that is possibly worn out in the groove of the main shaft, To inspect this key way devise you need to remove the top off the mower probably 4 phillips screws off the plastic housing comes dont forget to pull out the oil stick, then removethe pull chord assembly in one piece 3 rivets need to be drilled out and reinstalled with new ones from Ace hardware when done, then remove the 3/4" nut...tap the shaft not to hard to loosen the flywheel and check to see that the keyway(woodruff pin) is worn out, go to a hardware store with the old one and buy a replacement reinstall everything and mower should be good to go.
Jul 16, 2010 | Garden
I have a toro recycler lawn mower that was made in 2005 according to the sn. it wont start. we have tore it down to check everything but still nothing. It has spark. after pulling a few times we check the...
If you have spark and gas, it should start. The plug shouldn't be wet with gas, adjust the carbuerator fuel flow screw to reduce fuel to the engine. Use full choke to get it started
Jun 29, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
