Question about Microwave Ovens
Bulb has burnt out on microwave and I don't know how to change it.
  • Microwave Ovens Master
  • 8,404 Answers
Remove the cabinet to get access. There are about a dozen screws to remove.
Posted on Jul 06, 2010
Bulb replacement
I save any microwave i find thrown out. I take the parts off of many.. and yes they use a microwave light bulb. I don't know who sells them... likely an appliance parts place.
Jun 21, 2013 | Cuisinart CWM-100 Microwave Oven
I have to replace microwave light bulb. It's GE counter top Microwave JES1142PSE model. I hace opened the microwave and have located the bulb,but could not unscrew.I don't know needs to be pul
That exact model number is not showing up, so you may want to check the tag on or in the unit and look here for parts.
Most of the models in this class of ovens were not really made to be serviced, so GE only makes the turntable parts available.
It also sounds like your bulb is an assembly - the socket and bulb and one piece.
So your local appliance parts store should have a generic replacement for it. You should take the bulb.
Be careful when disconnecting the leads.
Apr 14, 2013 | GE Microwave Ovens
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE JES 1855 Microwave Oven, my light bulb burnt out there is no instructions telling you how to replace the bulb!
You have to take the out side cover off and there you will see how to change the bulb.
Jul 03, 2011 | Microwave Ovens
Do the lighbulbs underneath the microwave screw in or pull out- in the process of trying to change the burnt out bulb- i broke the bulb off of the base.
Most moderately new microwaves have a two prong pin type connector that is simply pushed strait in and pulled strait out. I presume the you tried turning it out when it broke?
Oct 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Light has burnt out
R-820BK/BW Microwave Operation Manual
Due to the risks of death or serious injury the above owners manual suggests that a burnt out light demands a service call by a qualified technician.
That said, if you have a basic level of competence and read the safety hazards involved with microwaves (see a good resource on microwave safety and repair at:
http://www.kellerstudio.de/repairfaq/sam/micfaq.htm
Often, the microwave is divided into two main compartments, the electronics compartment(usually immediately behind the front control panel), and the high voltage compartment(usually behind the electronics compartment). The light bulb is likely in one of these two primary compartments. If it is in the high voltage compartment with the HV Capacitor and magnetron, changing the bulb becomes much more dangerous.
Please be very careful if you do decide to do this on your own... unlike most electronics microwaves can remain lethal, even when unplugged. Hope this helps.
Oct 21, 2010 | Sharp R820BK 900 Watts Convection ...
Fan and light wont work / the bulb for the light burnt out. the bulb got broken trying to remove. I think it might be the fise, but i dont know where its located. Its a under the cabinet microwave. TOM
Mine is behind the control panel, removable from the front (after taking off grill and removing screw holding panel). I hope this helps. If not, check your instruction manual on how to remove the microwave.
Oct 21, 2009 | Microwave Ovens
Microwave light is burnt out
Accessing the internal light bulb on model KBMC140HSS bulb will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 14, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave range top lights
This looks like a new entry as opposed to a reply, so I don;t know what advice you got or from whom.
But based on your problem, I'd say I know your problem.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 13, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
