Question about Hitachi 32UDX10S 32" TV
Black display with a horizontal white line in the middle.
I have a hitachi 32 ultravision tv that has a black display with a white line in the middle. Is this something that would be too expensive to repair or is it just better to get a new set.. The unit has sound but no picture.. Sometimes no line either. Any recommendations greatly appreciated.
Thanks in advance.
  • 934 Answers
Middle going across the screen from left to right??
This unit is plagued with bad solder connections in the comb filter board and flatpack underneath the comb filter board. These connections can cause any odd number of problems in video display. If it is that it's not expensive - virtually no parts. If it's a single line across the screen could also be the vertical circuit involved.
My suggestion is to have it estimated at a reputable shop and take it to them rather than the more expensive pu/del charges.
If you would like go to and locate a servicer from there. Kinda like going to the AMA to find a doctor...
Hope this helps!
Posted on Apr 18, 2008
My 61" Hitachi UltraVision has
hello my name is rico, you have bad convergence problem. you need to replace the stks inside the tv, and look for colder on the boards. you gonna need a gun solder, solder, chawick, 2 stks(look in the tv for the number loooks like stk392-120 o something like it) look for bad fuses. that should fix your problem. if you need more help let me know at 602-810-7149.
Jan 07, 2011 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi digital ultravision 50"
Hello bugster421,
Can you post a picture of this problem? It will go a long way in determining what is happening.
Thank you,
Oct 26, 2007 | Sony KP-46WT500 46" Rear Projection...
Hi! my tv hitachi 50v500a ultravision had problem the screen of the tv have big red cloud
There is no solution - eventually the entire picture will turn blue. It's out of warranty and replacement of the light engine is way too expensive. Start shopping for another tv - I did
Dec 24, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Black screen with sound only no picture.
I have same problem,it appears to be the flyback
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
No picture or just one line across screen on hitachi ultravision rearproj.
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Mar 24, 2008 | Televison & Video
TV Screen
im pretty sure you cant fix that you probably need to buy a new one.. i know that because my somputer has a white line that runs right down that middle, not all the time but sometimes. my father looked into fixing it and he found out that you have to buy a brand new screen or tower or something like that.
Dec 31, 2007 | JVC AV-32020 32" TV
Hitachi 32UDX10S 32" TV Logo
191 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
