Question about Maytag MGR5880 Gas Kitchen Range
Oven heats very slowly,
Maytag MGR5780
Maybe oven ignitor.
Need part #
    Genius:
  • 1,075 Answers
Go to there website.adrian,,,
Posted on Jul 06, 2010
How do you remove the oven door from and Maytag MGR5780 stove. There doesn't seem to be any latches on the hinges.
Open the door part way until it rests open. Grasp door on side edges with either hand and pull straight up at the angle the door is resting.
Oct 23, 2013 | Maytag Heating & Cooling
How do you remove the oven door from a Maytag MGR 5780 range. I cannot see any latches on the hinges
There aren't any latches on the Maytag MGR5780 oven door hinges. You should be able to open the door to the first stop (about 4" from the closed position). Then grab the sides of the door and lift the door up at that same angle until the door clears both hinge arms. Manage My Life has the manual for the MGR5780 here: http://www.managemylife.com/mmh/owner_manuals/25316/MAYTAG-Free-Standing,-Gas-L0303326 . See page 15 (16 of the PDF) for a picture of the door open to the first stop position. You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
I have a Maytag (Magic Chef) gas oven model CGR3730ADH. The oven will not heat up. The ignitor will glow/heat up but there does not appear to be any gas flow. The top burners work normally. After...
HI,
First of all, thank you for all your information. A rule I live by, even if an ignitor glows does not mean it works. The ignitor works on the flow of electricity through it not how bright it glows. If you can use a amperage meter, hook on one of the two wire to the ignitor directly. You need 3.2 to 3.6 amps to open the safety valve. If lower than 2.6 amps, it will not allow gas to enter the burner. If you have no clue what I am asking you to do, you can purchase and replace the ignitor and life will be better. P# 12400035. Its not difficult to change, the screws holding the ignitor in place sometimes strip out, when you get them off, you can replace them if needed.
Good Luck
Jul 23, 2011 | Maytag Ovens
Bosch gas oven heating slowly - takes about 1 hour to reach 150 - 200 degrees. When trays placed in oven, temperature decreases cooking very slowly
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
May 19, 2011 | Bosch HBL 5032 Electric Single Oven
Maytag Gasline Oven - everything works fine - range and brolier start immediately yet oven clicks but does not heat anymore. Was working fine but no longer heats.
Oven not Working or
Oven not Heating
heatman101
Jan 18, 2011 | Maytag CWG3100A Gas Single Oven
Oven is set at 350 and the temperature will not go up.
f your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 09, 2010 | Maytag Ovens
Just won't heat food
we have a maytag wall oven. maybe the ignitor is bad. the oven usually heats up to 180* and no higher if it is the ignitor. the oven thermostat could be bad. we replaced the ignitor, the thermostat, and the oven control board on our oven before we got it to work. did not want to have to patch up our wall oven cabinet cutouts, is why we decided to try and fix ours.
Jun 19, 2010 | Maytag Ovens
If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
Jun 09, 2009 | Maytag MGR5870 Gas Kitchen Range
Oben takes half an hour to heat up
I doubt its the igniter. It could be a faulty gas valve or maybe the orifice is blocked, and not letting enough gas into the burner
Jan 28, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Jan 01, 2007 | Maytag MGS5870 Gas Kitchen Range
Maytag MGR5880 Gas Kitchen Range Logo
89 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
