Question about Microsoft Windows Server Standard 2003 for PC
Diffrences between win 2000 & win 2003 ?
What is the diffrences between win 2000 & win 2003 ?
The following feature not availbale in win2k
Ie-6
shadow copy
using saved queries unable to save users in win2k but in win23 able to save
Able to creat n number of users in win2k3 using dsadd command but that cmd not available in dms.
GpMC is new tool in windows 2k3
NTDS is new feature in win2k3
Posted on Apr 18, 2008
  • 76 Answers
Hi Sir Nice quition see what is the diffrences between win98 and XP u know sir ''''''''''' see below
********* win2000server and 2003 diffrence men Security and advanced server Tools is their ok byy*********
How to replace the drive belt tension on a 2008 corolla?
The first step is to remove the belt, this is a tight spot, heres a diagram of the tensioner, there are two types, spring tensioner or hydraulic, you will know the diffrence , i will show you the diffrence and also a diagram to remove belt and the location of the two bolts to remove the tensioner. good day.johnjohn2_124.jpgjohnjohn2_125.jpgjohnjohn2_126.jpgjohnjohn2_127.jpg
Aug 17, 2011 | 2008 Toyota Corolla
I cant find the tune up so what can i do ?
I doubt there is a tune up for the the handhelds if you can't find it i couldn't find it some radios you just can't tune iam sure there is a power pod for it but i don't think its going to make much diffrence for example iam running a cobra 19 dx 4 i did find the mods for it but no pod adjustments there were but
i was told not to adjust them because it just not worth the time not much diffrence. so they only adjustment was mod and spread some of the transmitt coils and i did get 2 watts out of the radio with a 15 watt swing . hand helds are for short range. If you have a external antenna hook up you could get more range that way hook it up to a mobile antenna check swrs though. hope this helped you.
Jan 26, 2011 | Cobra HH 38 WX ST CB Radio
The print for the reading is dark and the lines are all over the place. Mac1200 Thanks, Draya
If the ecg waveforms are all over the place you are probally recieving electrical interferance. If that happens when nobody is connected try adjusting the filters and see if it makes a diffrence. If it does not make a diffrence it might be the patient cable or leads.
If you have further questions you can contact me at wats@mesasales.com or through our website www.overstockme.com
Jul 15, 2010 | Ge Medical Systems Ge Marquette Mac 1200...
Diffrence bwetween ac in volts and dc
DC is direct current and AC is alternating current.
eg; 12 volts DC stays 12 volts constantly, positive or negative.
12 volts AC (at 60 Hertz or cycles per second) alternates from positive to negative then back to positive voltage again 60 times per second.
Sep 12, 2009 | GE JVM1790 Convection / Microwave Oven
Diffrences betweein oils
your bike does not use tranny oil.only motor oil.your gears are lubricated by your motor oil as well as your clutch.it works by a sump system.I use yamahlube for my bike.
Apr 20, 2009 | 2003 Yamaha YZ 125
How do i know if i need a fuel pump replacement?
when the car has a power diffrence or the the pump stops working you could go to a mechanic or a electrican for a check up
Jul 23, 2008 | Hyundai Sonata Cars & Trucks
Hyundia Trajet code 1723
P1723 A/t control relay - Stuck on.
This Code is showing that the main control relay of the transmission is stuck on. When that happens transmission goes in to the fail safe mode which is being stuck in 3rd gear to prevent damage to the transmission
Jun 25, 2008 | 2000 Hyundai Sonata
Asus 802.11 a/b/g wireless adapter problem
The problem could be with the wireless network that you are trying to access, or it has something to do with you wireless card tcp/ip protocol.
where you using the same computer now, when you had this issue with the vista? or is this win XP pc that you have now is a different computer?
if you are getting limited or no connectivity, that means that the access point (wireless signal) is not giving you a valid IP address.
you can try to add static to your IP settings, but this will only work if you knew the IP range of that network that you are trying to access.
please provide more info
Mar 25, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
All settings have changed to arabic mode
f8 in boot up screen and select safemode
Jan 04, 2008 | Acer Aspire 5580 Notebook
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Microsoft Windows Server Standard 2003 for PC Logo
98 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
