Question about Samsung HLR5688W 56" Rear Projection HDTV
As soon as I turn the TV on, a loud screeching noise comes out, and the picture is all distorted.
  • Samsung Master
  • 610 Answers
It sounds like the color wheel has failed and needs to be replaced. You can call 1-800-samsung to find the nearest service center.
Posted on Jul 06, 2010
Screeching noise
Your car needs alignment. The screaming noise comes from tires being dragged over aspnalt. This wears tires very fast.
Nov 18, 2013 | Cars & Trucks
We have a Polaroid 37" HD tv that has a loud
You have weak capacitors in the power supply and the signal board. I have not repaired this particular unit, but have experienced this with other Polaroid TVs. You will need a TV tech to replace those capacitors. It is a very time consuming task and requires patience and much care to remove the capacitors. Tell a tech that they must be very careful when they remove a cap in the signal board, as they can peel off a pcb trace. In most cases they replace the signal board, but the capacitors can be replaced! Thanks for asking and show a few hands of support!
Jan 03, 2011 | Polaroid FLX-374 37 in. LCD TV
Loud buzzing noise which became a very loud screech over the last week. Turning tv off and on seemed to remedy it. Today screen was only black and white, now no video only audio. Is this the picture...
This TV uses a lamp and color wheel. the color wheel is likely the problem since it is known to make noise over time and will eventually sieze. The repair is in the $400 range.
Sep 27, 2009 | GE 46GW945 46" Rear Projection Television
Loud sound of air and screeching tv keeps powering down
Sounds like a CRT is arching internally. to confirm remove the covers to have a view of the picture tube necks- in adimly lit room you should see bue arching in one of the tubes. (there are three piture tube with glass necks)
Sep 14, 2009 | Zenith R56W36 56" Rear Projection...
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
RCA HD50LPW175
Sounds like the color wheel is failing.
Dec 18, 2007 | RCA HD50LPW175 50" HDTV
Relay "Chatter" with good picture and sound
Sanyo Model AVM-1304 This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on. I can feel the mechanical vibration on the component. The Picture and sound are very good. The chassis is G6Y-13040. Any ideas? This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on replace relay as it is easily available or make it direct. .
Sep 11, 2007 | Televison & Video
Samsung HLR5688W 56" Rear Projection HDTV Logo
223 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
