Question about Frigidaire ATF6000ES Front Load Washer
Can't get the door open - Frigidaire ATF6000ES Front Load Washer
    President:
  • 1,382 Answers
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Posted on Jul 06, 2010
My chevoret epica 2007 makisg problem just driver side door open with key or remote other 3 door morotr sound but door not open when i lock the car all door locked at once but when i opnen car just...
Check your owners manual for your remote locking features.
It may be quite normal for a key fob to only open the drivers door...opening all the doors when you only need the drivers door open may present a security threat..anyone could enter your vehicle before you had a chance to secure the open doors. You should be able to unlock the doors you need open from the drivers door console.
Aug 30, 2017 | Cars & Trucks
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Door handles wont open doors
Fixed 1997 Ford Explorer Door wont open - YouTube
? 2:03
https://www.youtube.com/watch?v=Gs3eC8E-gbU
Sep 6, 2014 - Uploaded by craiwin
I fixed my 1997 Ford Explorer Door won't open problem! ... I have the same problem but my passenger side door on my 2001 Ford Explorer locked and won't open smh ... will this work for the rear passenger doors? ... How to Replace Rear Inside Door Handle Latch Cable 2002-05 Ford Explorer Mercury ...
98 Ford Explorer Door Won't Open Part 1 - YouTube
? 0:30
https://www.youtube.com/watch?v=oY4IcNdGK68
Apr 5, 2010 - Uploaded by gdellinger
A couple weeks ago the door handle just stopped working on the... 98 Ford Explorer Door Won't Open Part 1 ... The remote would open all other doors. ... on a Ford Exploer 91-2001 - Duration: 7:27. by diversity2 37,309 views.
98 Ford Explorer Door Problems- how to open without panel ...
? 4:22
https://www.youtube.com/watch?v=lJ0Fsh3561s
Jan 1, 2013 - Uploaded by inwinblades
98 Ford Explorer Door Problems- how to open without panel removal. inwinblades .... HELLO panel removal??? door won't open... Been searching all ... ok this better work on all doors, im aboutt o try this on my rear passenger door. .... I didn't care about the plastic door handle so i just "busted" it to pieces.
Rear doors can't open from inside - Ford Explorer and R
Jan 05, 2016 | 2001 Ford Explorer
How to open the door if no electricity
Almost all garage door openers have a switch mechanism that will allow you to open the door manually. It is usually a pull cord on the motor or track. Pulling it down usually deactivates automatic mode. Just pull it up into position when the electricity comes back on.
Garage Door Repair in Jacksonville FL American Garage Doors LLC
Mar 17, 2015 | Building Materials
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Opening mechanism inside front door not working - How do I get door open?
Parts are available at a salvage yard. Getting the door open is going to be your problem "unless" you pull the seat out and have room to take door panel off to open the door with the mechanism manually.
Sep 11, 2012 | 2000 Toyota Sienna
My power sliding door doesn't open fully. It makes clicking sound and a somewhat of a jerking motion. It open or closes slighty but the entire it makes the above mentioned noises. Any help would be...
I'm not sure about the noise, but the jerking motion might be because your the center roller (located in the rear middle of the sliding door) has worn out and need to be replace. This is a will known problem.
Your problem is very hard to answer because 05-10 odyssey has so many problem with sliding door.
rear latch:
-door not to latch close
-door not to work
front latch:
-door not to open
lock actuator:
-door not to open
-door will pop when opening
window motor:
-window not to work
-door will only open half way
center roller:
-jerking motion when opening
-door kick back close while opening
-door kick back open while closing
Door motor:
-door not to work
-cause door to jam
good luck
Dec 17, 2010 | 2005 Honda Odyssey
My DKE is acting up and now opens 2 of my doors with one code
If you press and hold the smart/learn button for 6 seconds on opener number 1 it will erase the memory and neither code will open it. Now just program it for button number one and you should be set. If you have remotes for door number 1 you will have to reprogram them also.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Fuel door won't open
ok check the sliding door on the side the fuel door is on. there is a safety mech. there the door needs to be closed all the way. if its not you can't open the fuel door. so slam that door then find out where and how it keeps the fuel door from opening. because if you open the door with the fuel door open it may damage fuel door
Jan 27, 2009 | 2002 Honda Odyssey
Frigidaire ATF6000ES Front Load Washer Logo
298 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
