Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door closes to fast and sometimes re-opens by itself
    President:
  • 3,197 Answers
A couple possibilities here. Make sure the door spring isn't broken. Your door is traveling too far in the down direction and when it hits the floor the safety sensor reverses it to the open position. The down limit adjustment is on the side of the motor unit.
Posted on Jul 06, 2010
Garage door opener just hums, won't go up or down
Either the motor has seized or the door itself has jammed. Unlock the manual release (Usually a cord or lever hanging down 1/2 way along the track) Sometimes if its a side mounted motor, the lever will be at the side of the motor .Pull the cord or move the lever, and the door should be able to be opened manually. If its stuck then you will need to check the tracks and rollers on the door and door frames to see whats jamming it. Repair or replace as required. If the door comes up freely, that will prove its not the door jamming.Try leaving the door in the manual position and turn the motor on. The door wont open or close itself when in the manual position, but the motor should run. If it still hums, I would say the motor has seized. Sometimes, its cheaper to get a new opener / motor complete assembly rather than a replacement motor on its own. Check with the manufacturer and or supplier of the door opener to confirm.
Aug 26, 2014 | Building Materials
FRIGIDAIRE DOOR WILL NOT STAY SHUT
check shelving and stock in door not stopping door closing. Check hinges tight and complete (sometimes have a self limitting plastic stopper that breaks, allowing weight of door to pull itself open)
Apr 05, 2014 | Frigidaire FRU17G4JW Refrigerator
Weird (Pressure Release) Noise After The Door Has Been Closed
The freezer being closed up tight and so cold can create a negative pressure inside. This negative pressure will cause the door to be very hard to open and could pull the door closed too quickly. Most manufactures today use small air valves the open and release as the door is being opened and closed. They are most often found on the bottom of the door itself or sometimes in the cabinet behind the back wall.
The noise is perfectly normal, my wife says it is there to alarm her when I am eating too many ice cream bars.....
May 03, 2010 | Frigidaire 14.1 cu. ft. / 399 liter...
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Dvd/cd drive door keeps opening and closing by itself
If the trouble isn't being caused by some screwy virus or software problem, the best solution is to replace the drive. New drives are quite inexpensive and widely available in retail stores (at higher prices) and online.
May 27, 2009 | HP (D4384-63002) (d438463002) Internal 32x...
Drum speed is too fast then sometimes does not rotate
Try just opening and closing the door. Sometimes cycling this switch fixes problems with washes not advancing.
May 11, 2009 | Washing Machines
Knocking and humming only when freezer door is closed
It sounds like the fan, which would not run with the door open. Be sure it is clear of all obstructions then fake out the door switch and see if this resolves the problem. If it doesn't it will confirm that it is the fan or not. If it is just replace it.
Good Luck,
Gilshultz
Apr 12, 2009 | Amana 22 cu ft Bottom Mount Refrigerator,...
Passenger sliding door
clean the contacts on the door jam and the door itself
Robert
Feb 01, 2009 | 2006 Chevrolet Uplander
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
56 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
