Question about Palm Treo 755p Smartphone
After a hard reset (reinstall battery while holding down the end key) I receive the ACCESS Powered screen. When I let the end key go I receive the prompt to delete all data. I key the up arrow and the ACCESS screen comes back and that is as far as the Palm will go. I do not see the Palm Logo screen. Any tips? Thx Kim
    President:
  • 567 Answers
Hi there if you can access the manufacturer website you should download the software available for your device, this should solve the problem.Simply go to the website and look for your model of palm and follow the steps.
Posted on Jul 06, 2010
How to reset cricket zio
WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
8. Allow the phone to completely reboot. This may take a few moments.
9. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
NOTE: If you receive a self-test screen or blue screen, the hard reset was done incorrectly. Please try again, from step 1.
Dec 02, 2011 | Cell Phones
Tip
Factory Reset for Treo 650 smartphone
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the palmOne or Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete.
on Mar 11, 2010 | Cell Phones
Tip
Factory Reset for Treo 700p and 680 smartphones
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again)
9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
My kyocera sanyo cricket phone screen is locked how to unlock it
Hard Reset.
1. Turn off the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
Phone is completely reset as if it came out of the box. You'll need to *228 and reload ALL of your data.
or WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
a)
b)
Procedure,
Sep 12, 2011 | Kyocera Zio M6000 Cricket
I need to hard reset my sonyo zio
Zio Hard Reset From Cricket corporate
a)
b)
Procedure, cont.
Nov 17, 2010 | Google Android
When I install my battery I get the Access Powered then Palm.
I have a Treo 700wx with very similar problem that I solved by starting a hard reset by holding down red button while inserting the battery... keep button down until the message comes asking if you are sure you want to do a hard reset.... I hit the space bar to abort it and IT STARTED UP normally ... worth a try... good luck.
Nov 18, 2008 | Palm Treo 755p Smartphone
Constent reboot - flashing Access Powered
There is a soft/warm reset which bypassed the loop without losing your data.  press the up key and reinstall your battery.  do not let go until the palm screen fully loads. when fully reloaded let go.  sounds a little confusing but the palm website has step by step instructions.
Sep 24, 2008 | Palm Treo 755p Smartphone
Can't reset
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 23, 2008 | Texas Instruments TI-83 Plus Calculator
Blakck screen
Batteries:
Hope that helps!
Jan 20, 2008 | Texas Instruments TI-83 Plus Calculator
Black screen
If one of these solutions doesnt work you will most likely need to purchase a new calculator.
Batteries:
Hope that helps!
Jan 12, 2008 | Texas Instruments TI-83 Plus Calculator
Palm Treo 755p Smartphone Logo
277 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
