Question about Franke Strainer Basket Sink Hardware
Use foam gasket on sink strainer along with plumber's putty?
If I am installing a stainless sink strainer, do I need to use the foam gasket under the top side of the strainer? in between the strainer and the plumber's putty? will the putty adhere to the foam gasket?
  • 760 Answers
Usually the gasket is not foam but black rubber. There may have been a piece of foam as packing to protect the stainless. You would apply the plumber's putty directly to the sink. Insert the strainer directly into the putty, compressing the putty. Under the sink, remove the excess putty that extruded through the opening. Apply the rubber gasket to the bottom of the sink, and then the nut (sometimes a "cup" and then the nut) .When the nut is tight, remove excess putty inside the sink. LEAKPROOF!
Posted on Jul 06, 2010
Leak at new strainer waste fitting
Did you put the rubber gasket and cardboard sleeve on the bottom of the sink(next to the nut and did you use plumbers putty on the top part of the sink under the top section of the basket. Hint if you put some soap on the gasket under the sink between it and the nut it will be easier to tighten also you must secure the top part of the basket as you turn the nut if not the plumbers putty will not seal. If you do not have the strainer basket holding tool wrench you can substitute with a pare of needle nose pliers. Large channel locks or pliers can work to turn the large nut on bottom. If you can recruit a helper to hold the top part of the strainer basket with the needle nose pliers it make the job of tightening the large nut easier. When a large amount of the plumbers putty has squeezed out and the strainer is flush with the sink you should have a tight seal.
Feb 24, 2012 | Blanco Plumbing
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket...
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Mar 25, 2011 | Franke Kindred DP2233/90/1 Granite Double...
What is the proper way to install a BLANCO sink strainer Kitchen Sink COD.100113 I believe is the code # Thank you
Hello, W/D here.
To install your strainer, you'll need some plumber's putty. The old one is removed by loosening the large ring on the underside and the strainer pulls out from the sink side. Once you are down to just the hole in the sink, you're ready to install the new strainer.
Get a portion of the plumber's putty in your hand about the size of a golf ball. divide it into two portions. Take one part, and roll it in between your hands, palms together and vertical, making a rope.
Take your rope, and place it around the sink hole. If you need more putty, roll the other portion in a similar fashion, and continue around the hole. You may need to overlap the rope putty where it's thin and at the ends to make sure that you get a good seal when you apply pressure the the basket. Place the strainer basket in the hole and press it down lightly, just enough to hold it in place. From under the sink, place the gaskets on the threads, followed by yjr large ring nut that will hold it all in place. Usually, there are two gaskets, a paper type, and a plastic type. Put the paper one on first, followed by the plastic, then the nut. Screw the nut down, applying some pressure to the strainer and plumber's putty. Adjust the strainer now, centering it in the depression in the bottom of the sink. Continue tightening the ring nut, pulling the strainer down into the sink, and squeezing the plumber's putty out, making a seal. Get it pretty snug, and wait a minute. The putty will continue to settle in the seal, and you will be able to tighten it some more after it does. Do this several times, and you'll end up with a good seal that will last. Take a regular screwdriver, and trace it around the strainer on the sink side to release the excess putty. You can ball it up, and press it back into the tub of putty, ready for the next time.
Best regards, --W/D--
Feb 09, 2011 | Blanco Sink Waste Strainer / Stopper...
Moen basket strainers for Corian sink Use plumbers putty and no rubber gasket
I'm not sure what your question is, or if you are posting information.
Plumber's putty is purchased at local home center, hardware, plumbing outlet.
Container is smaller than coffee cup, and 3 times heavier.
Material is gray and thick and slightly oily and not sticky on the fingers.
Clean sink opening.
Apply fairly thick amount of putty completely around sink opening. About 3/16" thick.
Putty should extend wide enough so sink basket sits entirely on top of putty.
Push sink basket down into putty.
Tighten sink basket very firm from below.
Wipe away excess putty inside sink bowl with finger, and then a paper towel or damp sponge.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 15, 2011 | Moen 22036 Stone Stainless Steel Sink...
There are no instructions with the product. 1. Do I need Plumbers Putty to get a good seal on the sink drain hole? 2. There are 3 washers: 1 thick rubber washer; 1 thin rubber washer; and 1...
If you want to use the washers you place the thin rubber one on the top under the basket... then place the thick rubber one on the bottom first and then the paper washer...then turn tight...
If prefer either plumbers putty or clear silicone instead of the thin rubber one on the top...
heatman101
Jan 11, 2011 | Moen 22036 Stone Stainless Steel Sink...
Two rubber gaskets and a fiber gasket came with new strainer. do i use all the gaskets? what about plumbers putty
You are attaching sink strainer to sink opening.
1) Use plumber's putty. Finger-size roll of plumbers putty is applied around opening from top, or applied to the bottom of strainer basket. (Some sinks require silicone. Do not use silicone unless required by the sink manufacturer.)
2) Sink strainer is pushed into the sink opening, making sure it is centered and level.
3) From below, the rubber gasket is applied first, and then the paper gasket is second, and then the basket locknut.
4) Tighten locknut very firmly.
5) Wipe away excess putty on bottom.
6) Push down stainer from top again, and tighten nut some more.
7) Wipe away excess putty around bottom and top.
8) The cardboard washer lets the locknut rotate easily.
Dec 18, 2010 | Moen 22036 Stone Stainless Steel Sink...
I have a kohler cast iron enamel sink. The
ALL BASKET STRAINERS ARE PRETTY MUCH THE SAME. PLUMBERS PUTTY WORKS FINE. I BELIEVE ITS THE ORDER OF INSTALL THAT IS CAUSING THE LEAKS. STRAINER AND RUBBER GASKET GOES IN FROM THE TOP. IF NO RUBBER GASKET IS PROVIDED, THEN PLUMBERS PUTTY WILL SUFFICE. UNDERNEATH, ANOTHER RUBBER GASKET AND/OR PAPER GASKET, THEN THREAD ON THE NUT. TIGHTEN IT SNUGLY.
Dec 25, 2009 | Plumbing
Do i need plumbers putty with the white and rubber large 31/2 inch washers with the 1135 strainer and where do each fit
yes you do. you put the putty under the chrome ring. the rubber and white gaskets go under the sink. i've tried without putty and it always leaked
Oct 29, 2009 | Kindred 1135 Standard 3 1/2 inch Basket...
I have a new push push drain from mac faucets, and it leaks. I have reversed the rubber gasket that goes under the sink (held on by the brass threaded ring assume that I don't use plumbers putty under the...
The order of installation starting from the top side is the flanged drain then a bead of plumber's putty, and don't skimp on the putty. On the bottom side, first the rubber gasket then the metal washer, finally the locking ring. You must use the plumber's putty between the sink\tub surface and the flange. My mom thought the same thing. She return her drain twice before she asked me why it was leaking:)
Hope this helps.
Sep 11, 2009 | Opella 2-3/8" Push-Push Drain Assembly...
Franke Strainer Basket Sink Hardware Logo
2,017 people viewed this question
Top Franke Plumbing Experts
Donni Steen
ray gallant
William Wurtinger
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
