Question about Maytag MSD2456G Side by Side Refrigerator
Where is the location of a defrost timer in the maytag refrigeraton?
    President:
  • 1,218 Answers
Good day,
It is located in the fresh food compartment on the top to the rear of the main controls.
You can tell where the exact location is because a small hole exists where a screw driver can be inserted and used to advance the timer into a defrost mode, or in some cases when the machine is off because it is in defrost to turn the machine back on. The advancing shaft will only turn clockwise.
Posted on Jul 06, 2010
Where is defrost timer reset switch on a Maytag mfd2561heb
This model Maytag has a defrost control board and not a defrost timer. Your control board is located at the top of your refrigerator behind the display.
Jul 28, 2016 | Maytag Refrigerators
My refrigeraton is not getting as cold as it should,bot the freezer is.Refrig temp 64 degrees.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | Samsung RB2155SH Bottom Freezer...
Where is the defrost timer on a maytag msd2556aew refridgerator?
HI. This unit is not equipped with a traditional timer. Your unit has, what is called an Adaptive defrost control board. This device is used to regulate the defrosting cycle, and heater assembly. The part number is 61005988, and it is located in the control housing section of the unit, just above the heat shield section.
Click here to see a picture of the module.
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer frosts up and will not defrost itself anymore. Do I need a new defrost timer and/or thermostat? If so, where is the timer/thermostat located in the refrigerator?
It could also have a bad defrost heater. The heater and defrost thermostat are located mounted on the evaporator coil and the timer is usually mounted in the control panel with the control thermostat or in the compressor compartment.
Aug 28, 2009 | Maytag Refrigerators
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
INSTALATION OF MAYTAG DEFROSTER TIMER
Hi, Here is a picture of the control panel where the timer is located. There is a1/4" screw holding the control panel up. Remove the screw and the control panel should release. The timer has a wire harness of 4 wires. It can only plug in 1 way.
Please let me know if this has helpes you at all or if I can assist you further.
Thanks
Vic
Jul 26, 2009 | Refrigerators
Maytag RSW2700 Freezer cold Refrigrator Warm
Check for excessive frost build up in the freezer on the back panel. This would indicate that you have a defrost problem. One of 3 things cause a ref not to defrost. Defrost timer may not be advancing to the defrost position on the timer...The defrost thermostat, located on the evaporator in the freezer, measures open (bad)...or you have a bad defrost heater. If you have an electronic defrost control,which is used on most Maytag, Jenair, or Amana units, this could be your problem. If you turn the unit off for 24 hours to let it defrost manually then it will last for about 2 weeks before freeze up again.
Apr 11, 2009 | Maytag Freezers
Maytag fridge defrost timer location
If this unit has the temp controls in the middle top of the fridge then it is in there.
Dec 24, 2008 | Maytag MSD2456G Side by Side Refrigerator
Maytag MSD2456G Side by Side Refrigerator Logo
160 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
