Question about Viking VCSB423 Side by Side Refrigerator
My wife took out the ice tray to clean it and when she put it back in something happened and now it doesn't make ice. I need help!
    President:
  • 1,891 Answers
Take the ice tray out again and reinstall it . be very carefull to get the bin arm in correctley or it will not make ice . mm
Posted on Jul 06, 2010
My Sub-Zero 561 ice maker works fine however when it dumps ice into the tray and fills back up with water, the water pours out on the right side and into the ice tray. any suggestions
I had the same thing - turns out the wife tried to put a wine bottle in to the ice tray to chill it - in turn it had pushed the water pipe back a little too far and so was causing water to spill out - see if you can pull the pipe forward a little - you will need to remove the ice cube bin - and get in to a funny angle to get to it -but its do-able.
good luck
Aug 28, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice maker will not change back from crushed ice to cubed ice.
you may not of gotten the metal rod on the bottom of the tray back in the right spot. remove the tray and slide it back in if problem persists you probably have a frozen or failed ice solinoid. this is behind the back wall and engages when you have cubed ice selected.remove the back panel and then remove solinoid and let it thaw rub the plunger with a little wd-40 and reinstall if you don't see any signs of the plastic melted or the p[l;unger remains stuck in the solinoid body. if problem reoccures replace the solinoid
Apr 24, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I took my ice tray out to clean it and when I put it back in, I only get crushed ice.
Make sure thew rod is going into the lever at the back. The white plastic plunger may be stuck in the up position if it is pop it back down and reinsert the ice bucket.
Feb 12, 2010 | Frigidaire FRS3R5EMB Side by Side...
Icemaker not working/whirlpool ultraease
I'm sorry I don't have a solution...I am having the same problem, except the water has stopped in the ice machine. I have the same make and model refrigerator. Is it common for the water valve in the back of the frigerator to go bad? Is the valve easily replaced? Where can I buy the valve? Is there a trigger in the rear of the freezer where the icetray connects? I also took my ice tray out and it doesn't seem to fit back in correctly. I'd rather take the ice machine apart myself before I call a technician who will charge me an arm and a leg! Any further advice would be appreciated. Thank you
Jun 28, 2009 | Refrigerators
Frigidaire side by side: water fills up in bottom of freezer
You have a blockage in your drain tube, at the bottom of the metal tray there is a hole which is connected to a tube which runs down the back of your refridge to a pan next to the compressor. It is an easy fix have done this 1000's times. Remove back panel in freezer, grab a heat gun or hair dryer and melt the ice it the bottom of tray. Clean the water in the tray with some paper towel next get some hot water in a measuring jug and pour into the pan(hot water will help melt ice in tube) repeat this process a couple of times and then get a curtain wire or something flexible to push down the pipe to clean the blockage...you will know when the blockage is clear because the water in the pan will suddenly drain off....put cover back on...make sure to unplug appliance before servicing...hope this helps :)
Jun 22, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
Ice tray not rotating
i left it alone for a couple of hours and mechanism seemed to kick back in.one thing i will advise.. empty the ice regularly
Jun 02, 2009 | Samsung Refrigerators
Problem with Benvenuto B30 cleaning
After I cleaned the tabs really well, I still had the same problem. So, I took the back off so I could get to the "switches" that close the feedback circuits for the "Trays Missing" and "Clean Trays" messages. Long story short, you DON'T need to take the back off. You can solve the problem if you remove the trays and carefully remove the right side metal tab. This will stop the false readings, at least it did for me. Save the tab if for some reason you need to it later.
To remove the right side tab, use something like an eye glass screwdriver or butter knife to pry it up and out of the two small holding tabs. Then rotate the metal tab up and away from the tray and it will fall right off. Pictures below. a9c5bc58-d1a4-488c-891c-2b50084d4d96.jpg 3a317125-915d-4f72-a472-8ae2ea938a3a.jpg 383c8eeb-4d14-467d-842b-ea47d989e30b.jpg bd453672-83d3-46db-8ab5-d9cac5576ad8.jpg da367966-03c1-462d-961c-c5a9605fe4f4.jpg
Dec 09, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
Ice maker freezed up and freezer not keeping items freezed up
Your automatic defrost system is not working which is the indication of the frost on the back wall. When the freezer does not come down to temperature it also affects the ice maker. This kind of problem is from a bad timer, defrost heaters or defrost thermostat. I do not think you want to tackle this problem yourself. Call a service man from an appliance store that handles your product and give him the same information you gave here with the exception of the removal of the frost on the back wall.
Aug 06, 2007 | Whirlpool 21.0 cu. ft. Top Freezer...
Pioneer DVD tray won't stop in 'out' position
my system was experiencing the same problem with the tray going in and out. i took the system srews out of the case , and opened the body up, there was a CD that had been dislodged from the tray while the wife had moved it to clean. removed the cd, works like new. hope this helps you.
Mar 24, 2007 | Pioneer XV-HTD520 Multi-disc DVD Player
Viking VCSB423 Side by Side Refrigerator Logo
171 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Audie Bogus
Audie Bogus
Level 1 Expert
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
