Question about HP PSC 2410 All-In-One InkJet Printer
Capping station won't go down (unlock)
I took out both of my cartridges and now I can't put it back. The capping station won't go down. It says on the printer screen "Insert Print Cartridges". I don't know what to do. HELP PLEASE!!
Control that you have removed the tape on the cartridges
and there is nothing else left inside for the printer can see them
regards
Keld
Posted on Apr 28, 2008
I can not manually move the printer carriage on my HP Photosmart B210e printer
Might be service station jammed.Service station work is to clean the print heads,stores spitting ink init as we as capping the print heads to protect from the nozzle drying..After switching off the machine service station capping the print heads and arrest the carriage assm for protecting the print heads, in this condition carraige assm wont come out until its released by service station. Its required expert to release the service station, if you force to pull it will damages the print heads.. You justify what you can do for this issue...If you are capable do it...But care fully
Jan 09, 2012 | HP OfficeJet Office Equipment & Supplies
My HP 940C printer won't move the ink cartridge
Symptom look like carriage jammed in service station,open cover gently try to pull carriage out if its jammed, open top & side covers, release service station capping through manually rotate gears, once its released, push carriage left side, remove service station & verify why its jammed, if found any breakage replace it, or clean it..but little bit technical skill required..see the similar diagram below:
Dec 22, 2011 | HP DeskJet 940c InkJet Printer
My hp officejet d135 all-in-one makes a "clacking" sound when turned on and the cartridge does not return to the middle when top lid is open?
hello, waste/ capping assembly is broken, i ahve tried many ways to repair without replacing, but found the best repair was to replace waste/capping station.
Sep 23, 2010 | HP OfficeJet D135 All-In-One InkJet...
Paper feed not working. green button and orange
I assume you mean that the power and resume lights are blinking. This signals a carriage stall. Open the top cover, if the cartridge cradle moves to the right, it isn't stuck and may be a one-time issue. If it is stuck, unplug the power to the printer. Open the access door and observe the carriage position. Clean any lint or paper pieces out. Remove any obstructions. Move the cradle and continue checking for lint, paper and obstructions until the entire area is cleaned out. If the print carriage started out on the left side, return it to that position to make sure the cartridges are back in the capping station. Look inside the printer along the cartridge cradle path for obstructions and remove any. Remove the rear access door and check for paper pieces, remove any obstructions.
Plug in and turn on the printer and see if the carriage returns to the left and reseats itself in the capping station. Close up the printer.
If this doesn't work, the printer may need service.
I hope this helps.
Mar 28, 2010 | HP DeskJet 5740 InkJet Photo Printer
Having reconnected recently the printer is operating normally except that nothing is appearing on the printed page
Please check for the capping station after powering on do you find any ink in the cap station if no ink found in cap station its p head nozzles may by blocked and try to clean from printer panel switch
May try to put some water in cap station and check water should be there until its try cleaning option and after force cleaning it will drain out if it’s happen properly its most chances are for p head nozzles may be block
P head need to be replaced for same
Nov 08, 2009 | Epson Stylus 680 InkJet Color Printer
How to remove the cartridge from hp photo smart 7960
Hello the manual way to release cartridge is
  1. Disconnect the power cord from the printer.
  2. Open the top cover.
  3. Look for the gray-colored carriage on the right side of the printer.
  4. Find the horizontal (bottom) edge of the carriage and follow it towards the back (or in) until it makes a 90-degree turn. Follow it down to the ¼ inch-high, black-colored capping station.
  5. Using a screwdriver or similar tool, push the capping station toward the back of the printer.
    NOTE: Do not pull on the ribbon cable when moving the carriage.
  6. Making sure to not push up on the carriage, move the carriage to the middle of the printer. If the carriage is still locked in place, push the capping station farther into the printer and try moving the carriage again.
  7. After the carriage is pulled out from the right-hand side of the printer, remove both print cartridges and store them according to specifications.
  8. Close the top cover.
Sep 03, 2009 | HP PhotoSmart 7960 InkJet Printer
Orange ink light keeps flashing and printer won't print
hello,
To correct this problem, unlock the carriage from the printer‘s capping station.
  1. Lift the lid to the printer (cartridges are on the right side.)
  2. Turn the printer off, then power it on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts.
  4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct.)
  5. Take out the cartridges and close the top cover.
  6. Reconnect the power cord. The power and the resume lights (green and red) should be on.
  7. Open the top cover, reinstall the cartridges, and close the top cover.
  8. The printer should print the alignment page.
  9. Print from another application.
    thank u
Jul 29, 2009 | HP DeskJet 920c InkJet Printer
Getting a system error 1180
System Error 1180: Capping Motor Error
Description:
Capping Motor over current is detected.
Corrective Action: Try the following:
When the ambient temperature is very low, the Pump Motor Tube becomes hard and the load on the Capping Motor is increased. Make sure that the Printer is in an environment where the temperature is not below -10oC or higher than +85oC.
The Capping Station has a Torque Limiter for up and down operation so that the Capping Station does not experience any over current. Apply grease on the shaft of the Capping Station Gear so that it helps with rotation.
Make sure that the Capping Station cables are connected correctly and are not damaged
If the Capping Motor cannot be rotated, replace the Capping Station
Replace the Main PCA if nothing above corrects your problem
Jan 15, 2009 | HP DesignJet 9000 InkJet Printer
Copys come out blank
A couple things can cause this you may not have tried yet.
  1. First in your printer driver properties, select the highest dpi setting and the correct paper setting for your type of printer.
  2. Run a print head cleaning cycle. Run up to five cycles in sequence. Print a nozzle check pattern after every one or two cleaning cycles to see if you have made any progress. On most printers, after approximately every fifth cycle, the printer will perform a more powerful head cleaning routine.
  3. Clean the capping station The capping station is a rectangular flat sponge surrounded by a raised gasket. When the print head is in the “parked position,” at the right side of the printer carriage, the gasket of the cap presses against the print head, sealing it. One purpose of this is to keep the print head from drying out due to air exposure. Instructions: (1) push the “ink change” button to move print head off the cap. Unplug the printer (2) Look inside the printer case, below where the print head was originally sitting, to find the cap or caps. A cap is a rectangular piece, approximately 1” high by 2” wide(3) Look at the cap, using a flashlight if necessary. It should be horizontal, not tilted at an angle. If it tilted, there may be a problem with the fixture supporting it. (4) Clean the cap. Sometimes you may notice a buildup of residue or liquid in the cap or on the gasket; other times you will not. Use a drinking straw to deposit warm water, or use the tube from the inside of a bottle of Windex to deposit Windex, onto the sponge. Use your finger to dispense only two or three drops of liquid at a time. The liquid will remain in the cap for a few seconds, but will soon drain out. Repeat this several times. Try not to let the Windex or water spill around the cap, and into the printer. (5) Fold a paper towel into a 4”x4” (10cm X 10cm) pad. Press the towel gently on the sponge to dab away ink and water or Windex. As you push on the sponge, push down and slightly to the right, to protect the spring-loaded mechanism that supports it. (6) Dip a cotton swab (Q-Tip) in water, and use it to wipe gently around the edge of the capping station gasket, to remove dirt buildup there.
  4. Ink flow problems can occur if the air channels on the top of the cartridge become blocked. Check to make sure the cartridges that their is not bits of machined plastic on the top that was not properly removed.
Jul 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
R 1800
where can i get a print head for my epson R1800 printer?
Mar 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
