Question about RCA F32689 32" TV
RCA F32689 32" TV will not turn on. Worked earlier today but now only clicks. No picture no sound. Fuse near power cord is ok.
techman
  • 3130 Answers
SOURCE: tv will not power up
no reset button ,sorry. The problem you describe is pretty common with this model as its a fault in the horizontal drive circuit or in the main power supply and without the proper service manual as well as the prober tools and equipment this set its not gonna get fixed. there are no panels or user changable boards as it is a solid state set. ptscorp.com could repair this board or exchange it with a referbished board but it would still requir some adjustment that a user may not be able to handle. time to call the pro.. Sorry couldnet help ya more.. Good Luck.
Posted on May 24, 2006
techman
  • 3130 Answers
SOURCE: T.V. DO NOT TURN
There could be a problem in the main power supply or perhaps the standby power supply. To me at a guess i would say there is most likely a bad capacitor in the standby power supply or there is a problem in the switch mode power supply. if you have no electronic troubleshooting skills, play it safe and take the set into a repair shop or replace it. Now a days, a 32" TV set can be had for under 200bucks. Good Luck
Posted on Jun 13, 2007
  • 236 Answers
SOURCE: RCA 32 in TV no picture no sound just a beeping noise TV power is on
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Posted on Aug 10, 2007
jerryg50
  • 1689 Answers
SOURCE: RCA XL100 Commercial Skip won't turn on
The power supply or one of the circuits that it is feeding has a short in it. It may be able to be serviced by someone who knows the product and is experienced at working on the model you have. There may be a question about parts availability for it.
You can call RCA to find out who the authorized service rep is for your area. This is something that most small TV service stores may not be able to repair.
Ask for an estimate before approving service. The repair for your unit may be expensive.
Jerry G.
Posted on Apr 16, 2008
muttandjeff
  • 359 Answers
SOURCE: TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Posted on Feb 06, 2009
Panasonic cinemavision 1080i power light blinks red twice, will not turn on
The clicking sound is a safety device that prevents that TV from starting because a fault has been detected.
The fault is also indicated by the two blinks. Two blinks point at a problem with one of the low voltage lines (it should be 15V) from the power supply. The PSU is the part to be tested and eventually replaced. Before calling the technician try to unplug the power cord and leave the TV to rest for about one hour before restarting.
Nov 18, 2013 | Televison & Video
It won't turn on
Check the fuse inside the TV . Also check the power cord for firm fit, if it is using plugable wire. Like in desk top PC
Jul 09, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
My RCA TV model 20F420T keeps turning itself on and off. What is causing this and how can I fix it?
just remove all the tact switches on the front of the tv and use the remote control all the time.
Oct 25, 2009 | RCA 20F420T 20" TV
1996 mustang v6. the radio worked fine earlier
Stock headunnits are picky about the power they get, and when you are taking it to the headunit, it is putting unwanted strain on it. I can help more if I know where you put the fuse too.
Oct 10, 2009 | Car Audio & Video
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
No picture, no sound, no lights, faint clicking sound, fuse ok
HT transistor, or rectfying diode from chopper transformer is blown.
Apr 24, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
No power to TV. No sound, no picture.
frist you need to check the fuse it is inside of tv by the power cord looks like this maybe a Panasonic tv did notsee any model number so i will gess as to what is wrong check fuse if blown need to replace with a white glass looking fuse of same value like i said dont know what model number this set is but the thermister could be at falt for the fuse to blow.
Mar 14, 2009 | Panasonic Televison & Video
MY TV IS CLICKING AND WON'T TURN ON
Good Day;
The most common problem with these Models/ Chassis' is IHVT (intergrated high voltage transformer) going bad. They have around 99% failure rate. T14401 > part number > 239111 >IHVT.
Try to get RCA part a little more pricey but more reliable then after market ones. You can tell if it's bad by the crust on the top of IHVT.
Good Luck, big IRISH.
Sep 11, 2008 | RCA P52926 52" Rear Projection Television
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
RCA F32689 32" TV Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
