Question about HP Pavilion N5475 (F3927H) PC Notebook
Replacing the hard drive in my HP Pavilion N5475
I am trying to replace the hard drive in my HP Pavilion N5475 and have done this successfully on many laptops, however this laptop does not seem to have a hard drive component door or an obvious area around the edges for one to slide out. I am thinking that I will have to remove either the keyboard or somehow seperate the shell. Can anyone tell me what the correct solution is and how to do it? Thank you.
    Champion:
  • 200 Answers
Try HP website they usually have good info on replacing parts by model #,,,,,,,,,,,
http://hp.com/support
Posted on Jul 06, 2010
Hp pavilion dv4 2145dx does not show hard drive in Bios
I'm guessing it doesn't load to Windows either.
Your laptop hard drive probably needs replacing.
You will need to reinstall your system too.
Jun 27, 2014 | HP NB199UA Pavilion Notebook
How to replace power supply on hp pavilion slimline s3200 pc
I have included a link directly to the upgrade and service manual for your PC. The directions for removing and replacing the power supply are not included. However, there are directions for removing the cover and identifying several parts.
I have replace many power supplies and it does take some attention to detail. I would suggest that you either diagram or put markers on all the cords you unplug from the origian power supply. Generally, the power supply is easy to find and is secured with screws that can be seen on the outside of the case. The power supply will plug into the system board, sometimes in two different places. The power supply also plugs into the hard drive, CD drive, floppy drive (if you have one).
You must be certain that you obtain the correct power supply that is the same as the old one you are replacing.
If you are observant, document carefully and go slow, you should be successful in replacing your power supply.
Here is the link to the manual. It has diagrams and images so you can see what is being described.
http://h10032.www1.hp.com/ctg/Manual/c00877796.pdf
I hope that this is helpful.
Brian
Dec 24, 2010 | HP Pavilion Slimline s3430f PC PC Desktop
At boot up I get the XP loading then stops. I get the blue screen of dealth. I placed the hard drive in another HP Pavilion dv 9000 and it works find. So, can I fix it or get a new motherboard
1. Try to clear all the dust by using blower and not sucking section. If possible use soft brush to clear any hard dust.
2. Try removing memory and replacing it after cleaning the slots.
3. Remove the processor and replace it in position, at the time of replacing even clean the heat sink compound and apply new heat sink compound.
After 1 and 2nd step try turning it on. It it does not help then only try the third step
Sep 05, 2010 | HP Pavilion dv9000 Motherboard
Wont boot. Black screen Hard drive light flashes 3 times then every thing goes quiet.
Does it completely shut-off on it's own? If so, then you're likely needing some component replaced. First check the RAM & and then the hard drive. If neither of these is causing the problem, then you're looking at some more serious work needing to be done on your laptop. Unfortunately, the only way to check your RAM is if you have some extra memory sticks to swap into your computer, or another laptop that is compatible with your laptop's RAM to try in it. The same goes for checking the hard drive too. Does your hard drive make alot of noise? If so, then that will probably be the cause. If you end up replacing your hard drive on your own, then be sure to order the correct hard drive. The size of the hard drive isn't really a big deal, though I recommend replacing it with something that is 160 GB or larger, since your original one was probably 160 GB. The interface for it will have to be SATA (Serial ATA), not IDE (PATA).
Apr 10, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
Hp pavillion dv6915n - no hard drive detected
We do not say that the hard drive is damage maybe the IDE was faulty already. You may open your laptop and check the hard drive. Try to replace the IDE to check if the hard drive is good.
Mar 31, 2010 | HP Pavilion dv6915nr Notebook
Problem replacing sata drive with eide drive in HP A1330n
if hard drive show in the bios setting and not loading the window then your hard drive not work properly.change your hard drive.
Jan 16, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
Will not boot
You might have a bad or worn out hard drive. After so many reloads of windows the drive can have problems. Try a different hard drive. And reload windows.
Dec 15, 2009 | HP Pavilion a705w PC Desktop
My hp pavilion crashed and won't work. the repair report says the volune is corrupt and can't be automatically repaired
This means your operating system has become corrupt. This most frequently happens as a direct result of bad sectors on your hard drive. I recommend replacing the hard drive and reinstalling the operating system.
Oct 19, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
HP Pavilion N5475 (F3927H) PC Notebook Logo
163 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
