Question about AcerPower FE PC Desktop
Have a Power FE which I bought in 2006 and am now just getting around to adding extra RAM. I have purchased 2 PNY 1 GB DDR 400 MHZ chips. When I install one of these chips into the left (as seen when upright) memory slot and leave the right one empty the system will boot and after saving the new memory in the BIOS the system runs well and it registers I have 1 GB of RAM in the systems screen. When I put in both chips the computer will initially turn on but then goes nowhere and the screen remains blank. When I try to put just one chip in the right memory bay the computer does the same thing. When I put the 1 GB chip in the left slot and put the 512 MB chip which came with the computer in the right slot I get jibberish on the monitor-multiple colored figures. What do I need to do to be able to have 2 GB of RAM on this computer?
  • Acer Master
  • 15,729 Answers
There is a BIOS update to version R02-A4. Please check and see if that is the bios version that you have on that machine. If it is not. You need to go to the Acer website and download and install the BIOS upgrade. Notice you can have a bad outcome from doing this. IT rarely happens BUT it can. If the Bios version that you have is current. Then what video cards do you have? Have you installed ANY hardware?
Posted on Jul 06, 2010
  • syaffe Jul 06, 2010
    Hi! Eyecue
    Thanks for your help! Unfortunately I will be away from my desktop until Wednesday evening so I will check the BIOS version then. Perhaps you can explain what adverse events could happen if I did need to download the new version. I am getting at least 1 GB of RAM now and the computer is running a bit faster so it may be better to let well enough alone if I have the old version. I have added some hardware over the years. The two pieces I can recall are adding a new HP DVD disc drive and adding a tape cassette unit so I could transfer my audio cassettes to digital files on the computer. I don't recall adding anything else. I have not replaced the video card and I will have to check tomorrow night exactly what it is. Again thanks for your help and especially getting back to me so soon!!!
    Sherwin
I want to know the specifications of the Gigabyte 7NF-RZ:- 1.The max support of the DDR ram 1 or 2 and to 1or 2 GB? what HZ should be used? Regards, Edwin s.
Hi, the mainboards homepage is here:
http://ee.gigabyte.com/products/page/mb/7nf-rz/
Your mainboard supports:
DDR 1, 333 / 266 mhz 184pin 3 x DIMM slots up to 3GB
The mhz is not so important
it can easy run with 400 mhz
if the cpu supports it.
Sep 14, 2011 | Gigabyte Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Regarding 250W SMPS
250 watt is low under any circumstances, I'd upgrade atleast to a 450 or higher, around 650watt to be extra safe.
Jul 06, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
Does D845GVSR supports DDR 400 MHz RAM?
unfortunetly your motherboard supports only 200, 266, and 333 MHZ
Nov 29, 2008 | Intel D845GVSR Motherboard
Use of DDR2 RAM in ASUS MOTHER BOARD
This motherboard only support DDR type of RAM up to 4GIG , 400 MHz • 333 MHz this are the support speed of DDR RAM, so you can go ahead upgrade up to 4 GIG of RAM and that will make your computer very fast...
Nov 04, 2008 | ASUS GeForce® 4 V9180SE MX 440, AGP...
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
AcerPower FE PC Desktop Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
