Question about TecnoWind TWD90 Kitchen Hood
How should be the ducting for a range hood? - TecnoWind TWD90 Kitchen Hood
  • 8,197 Answers
May I get the make and model # so I can help you with the ducting.
Posted on Jul 06, 2010
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
No ducting pipe inside the cooker hood chimney what do i need to duct outside
Depends...does the vent access attic?...if so...attach vent material from hood and penitrate roof with roof kit....at lowes
Dec 09, 2011 | Kitchen Ranges
Reinstall RANGE HOOD from non-ducted to ducted
You need to uas a 7 inch duct to duct it out. You can get all the info you need in the manual on the link below. Please give it some time to load. If you need parts you can call Sears at 1-800-4-MY-HOME.
http://www.managemylife.com/mmh/owner_manuals/2285/KENMORE-Range-Hood-L1002022?brand_name_search=233.55213.000+
Good Luck and please rate 4 thumbs up for the free answer
Aug 01, 2010 | Kenmore Kitchen Ranges
Range Hood ductwork.
The range hood will give off only minimal heat from cooking. You should be fine with what you are using.
If you read the directions on the can of great stuff it will tell you everything it can be used on and what the temperature rating is.
Oct 02, 2009 | Maytag Generic 30 in. Range Hood
Range hood installation
you can reseal the hole with aluminium tape
you can use screws with metal flat washer that has a rubber backing
May 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
GE Monogram Overhead Hood is drippiong water
I think you have a basic design problem here. I wish I could see drawings and digital photos. I think I would have found a way to run horizontally then down to discharge. I would not go up through the roof. The duct run would be stainless snap together sealed duct with a ceramic firewrap around it. At the intake Id place a bimetalic safety to open on fire with manual panic switches. The blower would be at the final exit point. You could add a small director piece on discharge. Virtually every kitchen I see is woefully designed and no where near GREEN. Lets expand this conversation.
Mar 19, 2009 | Kitchen Ranges
New range hood whistles on high
Please call Diana Vincent at 775-358-0263... or Jeff Bilyeu at the same number...
THEY WILL HAVE AN ANSWER!!!!
Thank you,
Lauren Kilmer
Dec 12, 2008 | Independent Inc. Laramie Wall Model - LARA...
Smell of neighbours cooking comes through hood fan! HELP!
It appears to me that each hood has a fan discharging air and odours into a common duct.
The only solution to me is to have a main exhaust fan at the very end of the duct continually sucking the air out of the duct.This way it will not allow the individual hood fans to pressurise the main duct,forcing the air to esape through the path of least resistance,which happens to be the neighboars hood.
It may be that such a fan is existent but switched off due to malfunction,or switched off for running costs reasons.
Mar 30, 2008 | Fantech SHL48 Insert Range Hood
TecnoWind TWD90 Kitchen Hood Logo
106 people viewed this question
Top TecnoWind Kitchen Ranges Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Anthony Kelly
Anthony Kelly
Are you a TecnoWind Kitchen Range Expert? Answer questions, earn points and help others
