Question about Radio Communications
Fm modulator hi, can you tell me how to use a epro fm modulator in car
  • woody83 Aug 18, 2008
    I recently purchased an epro Fm modulator and I can get it to switch from one song to the next automatically woithout having to click on the remote. Any advice?
I need philips pci tv tuner card driver philips 1730
Help Me,I need software and driver TV Tuner Epro Philips
PCTV PCI / 7130 PAL FM
May 08, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I lost my AM frequency. FM is working. What can be wrong?
Do you have an FM modulator installed? If so the added impedence is likely the cause of your AM problem. If not its probably the AFM (Signal Amplifier) is on its last legs. Check write-up here: Installing an FM Modulator in a 2005/2006 Volvo V50 (PDF format).
Try it and tell us news.
Feb 08, 2011 | 2007 Volvo XC90 V8 AWD Sport
When i use my epro live drums on live gigs i sometimes get no sound when i hit the pads specialy the snare pad
Not used this kit inparticular, but if there is a main "brain" or sound mudule, check sensitivity settings. If not, take the pad to the store where you got it as the internal sensor may have gone, or the link lead may be faulty.
Jan 16, 2011 | Pearl ePro Live EPLX205P/C31 Electronic...
Pleace help me ..... give me driver tv tuner epro philips 7130 pleceeeeeeeeee
Plz try this driver
http://www.mercury-pc.com/download_file.php?option=file&item_id=1514
Sep 18, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
EPRO Philips SAA7130HL TV
Pleace help me send me software n driver
Sep 02, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
HOW TO INSTALL FM MODULATOR ON HONDA ODYSSEY 2003 EXL
You simply need power, ground, and remote turn on (switched) - these can be obtained 9tapped into) from the back of the radio.
RADIO 12V white/blue
RADIO GROUND black
RADIO SWITCHED white/red
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 02, 2009 | Pyle FM Modulator For Mobile DVD's - PLMD2
Got a new mp3 fm modulator, no frequency is detected
u should set the fm frequency on your modulator as same as ur car radio. example, if ur radio states 100.00, set ur modulator 100.00 also.
Oct 10, 2009 | Virtual Reality Sound Labs VRFM7 MP3 FM...
Hi, can you tell me how can i listen calls through fm of my car?
Get a 3.5mm headphone adapter for your HTC phone. Use the line out to either a little FM transmitter (very fuzzy) or install an FM modulator in your car (better) or, if your car has one, plug directly into the AUX jack of your stereo. Google "htc 3.5mm adapter" for people who sell pre-made adapters.
Here's a fun do-it-yourself project for those of us without AUX jacks. He cuts up an HTC adapter to connect to a microphone and FM modulator so that he can make a home made speakerphone.
http://forum.ppcgeeks.com/showthread.php?p=580026
Jan 15, 2009 | HTC TyTN Smartphone
Radio Communications Logo
65 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
