Question about Kitchen Appliances - Others
Wayne Dalton Garage Door won't close
I have a Wayne Dalton WD-320 chain drive garage door opener. It was installed prior to our buying the house in 2003.
Last week, the door started reversing when attempting to close it - it would reverse and act like something was obstructing the sensor. I've insured the sensors are aligned and there are no obstructions. I then unhooked the garage door and closed it manually - no problem. When ''closing'' the opener without the door attached, it still reverses partway into the down cycle. I discovered the ''down force'' setting was set to low/normal, and I increased this into the mid-normal range, but that didn't help either. Any ideas?
ctf1800
  • 4402 Answers
SOURCE: Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Posted on Jan 10, 2008
Blue Dog
  • 75 Answers
SOURCE: garage door stops and reverses either way-up or down-
If the light on the opener flashes when this happens, count the flashes (which indicate the type of problem) and consult your owners manual.  If you don't have the owners manual, you can find a digital copy online at the manufacturer's website. Also, check your manual for an adjustment that tells the opener how much resistance you want it to tolerate before reversing.
Posted on Dec 22, 2008
  • 8 Answers
SOURCE: garage door opener does not reverse after hitting obstruction
release the door from the opener and see if door moves freely the check proper torsion by moving door up to 3-4 ft if it stays in this area torsion is properly set if not call technician to adjust torsion
if door does not move freely all the way up and down check for binding track alighnment and roller condition. the adjust closing pressure.
Posted on Jan 10, 2009
  • 244 Answers
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Posted on Jan 15, 2009
  • 3197 Answers
SOURCE: garage door opener won't close. travels 6-8 in.,
If you cannot get the light on the sensor to come on by tweaking it,making sure it is pointed at the other sensor and your wiring is not broken or shorted then your sensors need to be replaced.
Posted on Jan 08, 2010
Need instruction manual for Wayne Dalton Chamberlin WD 220 grage door opener
The LiftMaster or Chamberlain web site has instruction manual downloads for all the models.
Jul 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Can i use the ''clicker'' model CLT1 with wayne dalton quantam 3316
It is compatible with Wayne Dalton opener manufactured between 1983 and 1987.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to have security with a lost wayne dalton garage door remote
Go to this site and follow the instructions.
http://www.1stdooropeners.com/299264coding.htm
May 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a wayne dalton garage door opener and the light stop working after and over ride or over use I let the motor rest and work again but the light stop working I replace the light bulb and nothing...
Try unplugging the unit for ten seconds.If that dont do anything youre have to call wayne dalton they should warranty the light socket replacement ,super easy to change out.
May 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wayne dalton garage door is humming but wont open
Likely the plastic gears are worn out. Unplug the unit from power source, remove the cover, look at the gears. If worn, it will be obvious from the shavings from the gears. You can buy the gear kit on EBAY for a little as $20 depending on the manufacturer and model. Before removing the chain drive, lock a pair of vice grips on the chain and metal chain rail to keep the chain from turning from its current position. The gears can be replaced without removing the opener. Even if you have to remove the opener, it is a simple task. Most have four bolts that need to be removed and it will be in you hands.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door issue
stepper motor needs to be reprogram by a tech
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Appliances - Others Logo
298 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
