Question about Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v
Does flotec make simer
Is the flotec 1.5 hp the same as the simer 1.5 hp
3 Suggested Answers
  • 32 Answers
SOURCE: i got 1 year old flotec 3/4 hp pump and it take
I have had the same problem there are a few things that can cause it to take longer to shut off, if you are running a sand point well that's usually a sign that the sand point is clogging up,if you have a sistern or a dug well check the screen on the end of the suction pipe,another possible cause is the water level has dropped low enough the pump is having to work harder to pull the water up, you should also check your pressure tank and the points for the pump if the points are sticking the pump will keep running till it builds enough pressure to trip them.Check for leaks in the suction line, if it is sucking air that would cause it to run longer to.I hope these suggestions will help fix the problem. Have a great weekend
Posted on Sep 05, 2009
  • 512 Answers
SOURCE: STORES THAT SELL FLOTEC 1/3 HP MODEL NO. FPSC2200A-08 115 VOLT 60 HZ 9AMP SUBMERSIBLE PUMPS
Your best bet is to get off this site, go to Google or Yahoo or any other search engine and type in "Flotec Pumps" and you will get several thousand places to shop.
Posted on Oct 07, 2012
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Aug 30, 2015 | Flotec Pump FP4022-10
No water pressure and we just put in a new pressure tank and pump
Hi j_rodrigues5
Make sure you have about 1/4 of the tank with air...it acts as a cushion and ensures that the pressure pump will turn on and off as needed.
Bud
Apr 04, 2013 | PENTAIR WATER - FLOTEC- SIMER FP7110T 19...
Where can i order a part for fpos 400x the piece that you attach the hose to at top of pump snapped off
If the fitting is a standard size, you could try repairing it with some plumbing fittings and pipe dope. Good luck!
Nov 15, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
I have a Flotech FPOS1790PCA Pool pump that will run for 15 seconds and then shut off...how do I get it to stay running?
I have the same model and found that it frequently shuts off when it gets too much pine needles clogging the strainer.
I have unscrew the bottom "skirt" almost once a month and clean it out.
Nov 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Pool pump not working
there would not be a fuse if this has a reset button I would suggest you return to company you got it from and have them replace the defected one thank you
please rate me
Apr 19, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
I have an Simer pedestal pump and the part that connects to the impeller from the motor is broken. I can not find a repair part or part #. Can you help me? THX
there is no repair parts all you can do is change the pump,, go with a submersable zoeller pump best on the market for the price aprox 100,
Mar 15, 2009 | Flotec 1/3 Horsepower Economy Pedestal...
I need a power cord for my 1500 gph 1/6 HP Flotec submersible pump. where can I get one? Cat # u2 Serial # 50833
Get ready for sticker shock:
http://www.abtecparts.com/simer_cords.htm
Simer and Flotec parts are interchangable.
Feb 17, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Jan 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v Logo
114 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ryan Ross
Level 1 Expert
Are you a Flotec Garden Expert? Answer questions, earn points and help others
