Question about Samsung SL620 Digital Camera
What do i do if theres a line thats showing in the center of the monitor???
    President:
  • 1,382 Answers
You no need to fix this problem. This is a CCD failure and in some cases had been subject to a recall.Contact Samsung support this may be one of the recalls and replacement camera could be on its way. They will do it for free of cost.
Thank you !!
Posted on Jul 06, 2010
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Getting vertical line in acer monitor
Apparently it is a display hardware problem. Try another monitor with the same cable and video card. Then you should try another cable. Then another video card. If vertical line doesn't show in either case, then you should replace the appropriate device\cable. If it shows anyway, then bring your monitor to service center for diagnosis.
Jul 13, 2010 | Acer Aspire™ T180 PC Desktop
25mm wide white line down the screen near center
Please make clear that whether it is showing from when you boot your computer to loading desktop then LCD is damaged mean to say its hardware problem so take your notebook to HP service center.
other wise remove VGA drivers and re install. To Check Driver Problem... Attach One Extra Monitor to your laptop and ensure that line is not showing on that monitor.
Mar 21, 2010 | HP Compaq nc8000 Notebook
LGM578RIO1OOGRNAO-TO2, have this box with the letters showing at
There should be buttons on the monitor that will help you with menu issues if you don;t have a remote for it.
You also might want to Google the correct monitor,, as the one that you posted does not exist.
Jan 15, 2009 | Neovo F-417 17" LCD Monitor
Distortion in Monitor
Your problem is simply a leaky capacitor on the vertical oscillator circuit on your monitor. Try replacing the ones with 10uF values.
Aug 10, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Shows half screen only!
if you can't expand your screen size from the pulldown menu or vertically or horizontally center the picture one or two of the centering coils could be partially burned out. the monitor uses electromagnets around the crt neck to center the picture. varying the center controls apply or take away voltage from the coils to center the image. may be time for a new monitor
Jun 08, 2008 | Compaq MV 540 15" CRT Monitor
Vertical white line in center of monitor
Your monitor may have been cracked somehow...
Try restarting and look to see if the line is there immediately from the start or does it only show up when your operating system (windows/linux) loads?
Regards,
Chester
Jan 11, 2008 | Dell Inspiron 2200 Notebook
IMac Monitor
What type of monitor is this? If it is an LCD screen, you may have some dead pixels. Please reply with some more details about your specific monitor.
Sep 05, 2007 | Apple iMac G5 Desktop
NEC 77F CRT monitor - displays alternating black \ white crosses
Sounds like its stuck in test mode. Make sure that none of the buttons are stuck in place and does it make any noise while its turned on?
Jul 19, 2007 | NEC MultiSync 77F 17 in.CRT Conventional...
Squiggly lines in the center of the monitor
sounds like you have what are called dead pixels. This typically happens in monitors that are about 2+ years old. If you are still within warranty i would contact hp about getting it serviced.
Sep 30, 2006 | HP Vs17 17" LCD Flat Panel Monitor
Samsung SL620 Digital Camera Logo
157 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
