Question about Frigidaire FRS26KF5C Side by Side Refrigerator
Model FRS26ZRF---Water forming ice block on bottom of freezer
I defrosted the ice block yesterday and it started forming ice on the
bottom again today. I pulled the unit out and cleaned the coils
underneath. The coils were quite dirty and probably wasn't cleaned
in a couple years.(or longer) The cardboard back cover was just
about plugged,also. Now I'm waiting to see what happens.
RTH
    President:
  • 1,891 Answers
I ll tell you whats going to happen . the clean coils will helt it to freeze up sooner . that part is good / but the ice problem is a defrost problem caused by the heater or defrost control failure . so keep on working your not done yet .. .you will find the heater and defrost terminater inside the fack of freezer .. mm
Posted on Jul 06, 2010
Water leaking from bottom front, ice in bottom of freezer
Your drain line form the evaporator is clogged. Locate the drain under the back and use a wet/dry vacuum to unclogged drain. The drain line can be also blocked by excessive ice buildup from incomplete defrosting. Remove frozen foods and open door to freezer section and remove power and manually defrost unit. Once ice is stopped melting try vacuuming the drain line again. Sometime drain line gets clogged with debris such as garden peas, corn, wrapping and the like. Once drain line is cleared the water and ice on the freezer bottom should stop forming.
Hope this helps
Dec 12, 2014 | Refrigerators
22 cubic
It sound like you have a blocked defrost drain. You will more than likely have to remove the freezer back panel and defrost the ice and flush the drain. Hot water works best but have a bunch of towels.
Oct 04, 2014 | Refrigerators
Ice forms as large block not in cubes
Defrost thermostat is bad. Defrost element is staying on for too long raising up temperature causing ice to melt.
Mar 26, 2014 | Fisher and Paykel Active Smart E522B...
Ice is forming on the bottom of the freezer. we removed the ice once but it came back again.
That sounds very typical of a blocked defrost drain.This tip i wrote will tell ya how to clear that blocked defrost drain. http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
GENE
Sep 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice forms in bottom of freezer on frigidaire
dependant on appliance you may have a small drain hose at the base of the appliance that drains the defrosted water away at regular intervals. Sometimes this blocks and the water that should drain away just starts to freeze over.
Mar 19, 2010 | Frigidaire Freezers
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Gets to 35-40 degrees then doesn`t maintain till is shut down and started over again.
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 21, 2009 | Refrigerators
I had a huge block of ice on the bottom of my freezer that I got rid of yesterday. Over night the ice started to form again. What could be wrong? The unit is only about 8 years old and we've already had...
Aug 19, 2009 | Refrigerators
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Frigidaire FRS26KF5C Side by Side Refrigerator Logo
296 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
