Question about Grilling
Cant get bbq to light
We have only used this bbq a hand full of times and today the electric ignitor will not work. we have replaced the battery and turn the propane on and there is no spark to light
    Champion:
  • 274 Answers
Make sure the battery is in correctly, then check the wires from the ingniter to the electrodes, if they are connected and ok, then check to see if there is a spark from the tip of the electrode to the collector box or burner. If there is no spark, then it could be the igniter, electrode or wire. Hard to tell with out trouble shooting.
Posted on Jul 12, 2010
Why wont the left and right burners lite using the electric ignitor?
Are the igniters for those burners sparking?
Aug 29, 2014 | Grilling
How to replace the battery on a bbq electronic ignition
Most of them don't have a battery at all. They operate by piezo-electric ignition. When you operate it, a spring strikes a crystal with a little hammer, and this causes a discharge of voltage and a spark. If it has ceased to work, there is an adjustment you can do
https://www.youtube.com/watch?v=c_sEDsyOCzE
or replace it cheaply
http://www.theartofdoingstuff.com/karen-answers-how-to-replace-a-busted-bbq-ignitor/
Mar 22, 2014 | Kitchen Appliances - Others
This is aCG4TDBN (elite with no back burner) aprox 6 years old. The ignitors are starting to go bad. How do I replace them?
First, you need to determine if it is the spark ignitors going bad or the Ignition Module.
If the spark ignitor tips are covered with grease or residue, this will give them the appearance that they're failing. Cotton balls and alcohol, work well to clean the spark ignitors. Also, check the wiring from the spark ignitors back to the ignition module. There may be some wear or even a burn on the wiring. Change the battery in the ignition module. Be sure the new battery is facing the same direction as the old battery, when you install it. Before installing the new battery, check the battery holder for corrosion on the contacts. If you see any, use a Q-Tip and WD40 to remove it.
As far as replacing the ignitors is concerned, you may only have to replace the spark ignitors and not all the wiring. It depends on how the wire is attached to the spark ignitor. If it can be carefully pulled of the bottom tip of the ignitor and then si back on, all you need is the spark ignitor. If not, you'll need the spark ignitor with the wiring attached. All of the wiring, will then have to be fished back to the ignitor module.
More more info on all the parts you may need contact BBQ's Galore 800-752-3085.
I hope this helped you to troubleshoot and determine if any parts do need replacing.
Jun 30, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
Have a bbq grill with a XINDA ignitor that fires on all three burners at the same time. Replaced the battery and can hear a faint "squeal" when I press the button, but no spark.
The battery may be facing the wrong position. Generally, the Positive (+) end should be facing you when you insert it into the holder. If you did that correctly, check the spark ignitors at each burner. If they are covered with grease they will not fire.
Mar 27, 2011 | Grilling
I have a dacor bbq in an island. Today we had very heavy rain. With that said, the lighter was on and making the typical clicking noises. I made sure that the gas was not on. Finally, I turned on the...
The really odd thing about this, is one shouldn't affect the other. So, I suspect that some moisture got into the ignitor button or module during the heavy rain and is causing the ignitor to button/switch to make contact when it shouldn't. Dismantle the ignitor button, remove the battery and check for moisture. Even if you don't see any, use a Q Tip lightly sprayed with WD40 to clean the interior. The WD40 will dissipate any moisture and help to lubricate the contacts.Then check all the wiring from the module to the burner ignitors to make sure they are not grounding out on something that the wires shouldn't be touching.
Hope this helps to solve your problem.
Mar 21, 2011 | Dacor 52'' Builtin Outdoor Grill Cover...
Used oven yesterday..... worked perfect. Went to turn in on today.... ignitor glows, but oven burner will not light. Any suggestions?
ignitor loose capacity... in order for gas valve to open ignition level have to be not less then 3 A. if it less then ignitor will glows but gas valve want open... So you should replace ignitor, but if you have tools (electric meeter) check if it's less then 3A, you can check one of the two wire on ignitor...
appliancesrepairla.com
Jun 26, 2010 | Kenmore Ovens
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
My reddy heater ignitor button will not click
No click at all? Replace the ignitor. Click but no spark, the wire broke off the sparker.
Find a replacement where you got the heater or at any full service gas supplier (dont forget the guy that sells BBQ equipment)
Jan 03, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
Jun 21, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Grilling Logo
332 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
